[Mapserver-users] Building a legend - with class objects in
layers
Eric Bridger
eric at gomoos.org
Tue Jun 15 09:11:52 EDT 2004
On Tue, 2004-06-15 at 04:42, Richard Orchard wrote:
> hi,
> I am using mapserver to display some geology datasets.
> A particular layer has multiple classes in order to show the various
> features (different rock types). The features are color-coded, therefore, i
> need each feature (class) to display in the legend.
> However, when the legend is generated, it just creates one item, based on
> the layer name. it doesn't iterate through the various class objects.
> Is this the way it is supposed to work?
Yes.
Or is there a way to get it to
> create a legend item for each class item within a layer. At present i am
> creating new layer objects for each item i want to display. I have put the
> map file i am using at the bottom of this email.
The map file you sent has only one class per layer. Perhaps you should
send the map file which is not working as you expect. Each CLASS must
have a NAME for it to show up in the legend.
