[Mapserver-users] Mapserver 4.2.0 Template Weirdness
Markus Spring
m.spring at gmx.de
Thu Jun 17 11:59:04 EDT 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Dirk Jesko wrote:
| Hi Marcus,
| I might have an explanation. It seems to be a bug with the linux version.
| The windows binaries work just fine.
| I had the same problem with [layers] today. If &layers=layer1+layer2+layer3
| is passed to mapserver, all layers are displayed, but only the last is
| returned (layer3) to the [layers] variable in the template.
| The reason seems to be the processLine function in maptemplate.c. The
| snprintf function used to replace [layers] with the actual values does not
| work the way it should (on linux systems). I replaced snprintf by strcat,
| which works perfectly for me.
Hi Dirk,
you are definitely right on this! How come nobody has stumbled over it until now???
Are you going to file a bug about this or shall I do so?
Kind regards
Markus
|> -----Ursprüngliche Nachricht-----
|> Von: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-
|> admin at lists.gis.umn.edu] Im Auftrag von Markus Spring
|> Gesendet: Donnerstag, 17. Juni 2004 13:16
|> An: mapserver-users at lists.gis.umn.edu
|> Betreff: [Mapserver-users] Mapserver 4.2.0 Template Weirdness
| Hi list,
| checking the 4.2.0 CGI mapserver, a ran across a weird template problem
| regarding the [layer], [layer_esc] and [toggle_layers] variables.
| The output with the same querystring of
| &map=/home/springm/perl/Geo-
| UMNmapserver/t/maps/verwaltungsgrenzenflur/verwaltungsgrenzenflur.dfo.map
| &mode=browse
| &layer=l1
| &layer=l0
| &layer=bgl15
| &layer=bgl11
| &layer=bgl20
| &zoomdir=1
| &zoomsize=2
| &mapsize=400+300
| &scale=9700
| &mapxy=4465711.0965965+5341175.7092885
| (of cours all in one line) returns:
| <!-- MapServer version 4.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
| SUPPORTS=FREETYPE INPUT=TIFF INPUT=JPEG INPUT=SHAPEFILE -->
| => layers: l1 l0 bgl15 bgl11 bgl20
| => toggle_layers: bgl99 bgl20 bgl11 bgl00 bgl00 bgl00 bgl00 l0 l1
| bgl98
| bgl15 bgl08 bgl08 bgl08 bgl08 bgl08 bgl08 MSSuser __embed__scalebar
| __embed__legend
| and
| <!-- MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
| => layers: bgl20
| => toggle_layers: __embed__legend
| I have no explanation for this behavior.
| Kind regards
| Markus
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
| _______________________________________________
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFA0b/IxxUzQSse11ARAqxOAJ9/t/u/DzJ2+OiC8bLgYXPYXvJkvgCfcvot
zc+MX6AeTlXCJruCpuOKjkQ=
=fCs0
-----END PGP SIGNATURE-----
