[Mapserver-users] ESRI Ascii grid format...
Delfos, Jacob
jacob.delfos at maunsell.com
Tue Jun 22 20:49:23 EDT 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C458BB.ED6B0900
Content-Type: text/plain
It's a bit tricky. You cannot always go on a 'line by line' basis. It tells
you how many values per line, and after that it just dumps the values in
consecutive order. It's for you to decide when to go to the new line (based
on the number of values per line). I think the linefeed comes after a fixed
number of values, irrespective of whether it's reached the end of the data
row yet.
I had a headache with this once, so I wrote a JAVA program to convert it to
XYZ delimited ascii. Just type "java Contour [inputfile] [outputfile]" at
the commandline.
Regards,
Jacob
-----Original Message-----
Sent: Wednesday, 23 June 2004 7:19 AM
To: Jason M. Nielsen
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] ESRI Ascii grid format...
On 2004-06-22 15:13 -0600, Jason M. Nielsen wrote:
> I have some ascii files dumped as the AAIGRID format from gdal. These
> are esri ascii grids.
> The format appears simple:
> ncols 98
> nrows 172
> xllcorner 1044355.808370659710
> yllcorner 10042832.567399607971
> cellsize 91.442854747403
> *then the z values are listed for each line*
> Problem is I dont know which friggin way these go. I tried left to
> right starting lower left and incrementing x and y. I end up with
> skewed data.
> Does anyone know where I can get the specs on this format that
> explicitly explain in thorough detail how its formated?
I'm pretty sure the first z-value is the upper-left corner of the grid, and
that it proceeds left-to-right, then down. I have used GMT (Generic Mapping
Tools (http://gmt.soest.hawaii.edu/)) to handle such files, and had success
using these assumptions. Sorry, but I don't know where the specs are.
Bruce
Bruce Raup Phone:
303-492-8814
National Snow and Ice Data Center, U. of Colorado, 449 UCB, Boulder, CO
80309 http://cires.colorado.edu/~braup/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: application/octet-stream;
name="Contour.java"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="Contour.java"
import java.io.*;
import java.util.*;
public class Contour
public static double leftX;
public static double lowY;
public static double rightX;
public static double highY;
public static int numRows;
public static int numCols;
public static String inFile;
public static String outFile;
public static double [][] datagrid;
public static double Xspacing;
public static double Yspacing;
public static void main (String args[])
try
inFile =3D args[0];
outFile =3D args[1];
//leftX =3D Double.parseDouble(args[2]);
//lowY =3D Double.parseDouble(args[3]);
//rightX =3D Double.parseDouble(args[4]);
//highY =3D Double.parseDouble(args[5]);
readFile();
writeFile();
catch (Exception e)
System.out.println("Usage: \n\n java Contour [inputfile] =
[outputfile] ");
public static void readFile ()
String readString =3D "";
StringTokenizer token;
String dataOutput =3D "";
String tempNum =3D "";
try
RandomAccessFile inputFile =3D new RandomAccessFile (inFile,"r");
//inputFile.readLine();
System.out.println("opened file");
readString =3D inputFile.readLine();
token =3D new StringTokenizer(readString, "\n\r ");
token.nextToken();
numCols =3D Integer.parseInt(token.nextToken());
token.nextToken();
numRows =3D Integer.parseInt(token.nextToken());
System.out.println(numCols);
System.out.println(numRows);
token.nextToken();
leftX =3D Double.parseDouble(token.nextToken());
token.nextToken();
lowY =3D Double.parseDouble(token.nextToken());
token.nextToken();
Xspacing =3D Double.parseDouble(token.nextToken());
Yspacing =3D Xspacing;
rightX =3D leftX + (numCols-1) * Xspacing;
highY =3D lowY + (numRows-1) * Yspacing;
while ((readString=3DinputFile.readLine()) !=3D null)
dataOutput +=3D readString;
//System.out.println(dataOutput);
System.out.println(leftX + "\n" + lowY + "\n" + rightX + "\n" + =
highY);
datagrid =3D new double[numRows][numCols];
token =3D new StringTokenizer(dataOutput, "\n\r ");
for (int i =3D 0; i < numRows; i++)
for (int a =3D 0; a < numCols; a++)
{ =20
tempNum =3D token.nextToken();
//System.out.println(tempNum);
datagrid[i][a] =3D Double.parseDouble(tempNum);
//System.out.print(i + ", " + a + " ");
//System.out.println(datagrid[i][a]);
=20
catch (IOException e)
System.err.println("IO ERROR");
System.exit(0);
public static void writeFile()
//double Xspacing;
//double Yspacing;
double Xcord;
double Ycord;
//Xspacing =3D ((double) rightX - (double) leftX) / (numCols-1);
//Yspacing =3D ((double) highY - (double) lowY) / (numRows-1);=20
try
RandomAccessFile outputFile =3D new RandomAccessFile (outFile, =
"rw");
outputFile.writeBytes("X,Y,Z\r\n");
for (int i =3D (numRows-1); i >=3D 0; i--)
{=20
Xcord =3D leftX + (Xspacing * (double) a);
Ycord =3D highY - (Yspacing * (double) i);
outputFile.writeBytes( (new Double(Xcord)).toString() + ',' + =
(new Double (Ycord)).toString() + ',' + (new =
Double(datagrid[i][a])).toString() + '\r' + '\n');
System.exit(0);
name="Contour.class"
Content-Transfer-Encoding: base64
filename="Contour.class"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------_=_NextPart_000_01C458BB.ED6B0900--
