[Mapserver-users] unable to affect HTML legend via URL arguments
to map file elements
Emilio Mayorga
emiliom at u.washington.edu
Tue Jun 22 23:23:18 EDT 2004
Daniel Morissette wrote:
> Emilio Mayorga wrote:
>> I'm trying to impact the output of an HTML legend by using URL CGI
>> arguments. For example, if in my map file there is a layer with these
>> elements:
>> NAME "countries"
>> GROUP "political"
>> I want to change the group to "admin" on the fly using this URL CGI
>> snippet:
>> &mode=legend&map_countries_group=admin
>> However, the HTML legend seems to be completely unresponsive to
>> changes passed via the map_<layer name>_<layer subelement> syntax
>> (I've tried various changes). Is that so, or am I doing something wrong?
> I had a quick look at the code and I see no reason why the HTML legend
> would react differently to those layer changes than the other modes. Are
> you able to change the group value when using browse mode? Which version
> of MapServer are you using? Maybe that's a bug from an older version?
Thanks for looking into it. I'm using Mapserver 4.0, on RedHat 8 (sorry,
I forgot to mention that). I've tried changing different layer elements
(not just group), with no success. I just tried making a layer change
while on map mode (map_countries_class_size=10). Here's the URL:
http://basin.ocean.washington.edu/cgi-bin/mapserv?mode=map&map=/var/www/html/mapserv/mapache/eng/mapache.map&mapext=-89.7117+14.0558+-85.834+16.9558&mapsize=600+449&layers=countries+departam_ln&map_countries_class_size=10
The change works. When I try the same change using legend mode with HTML
legend, it doesn't change the legend symbol for the "countries" layer.
Here's the URL:
http://basin.ocean.washington.edu/cgi-bin/mapserv?map=/var/www/html/mapserv/mapache/eng/mapache.map&mode=legend&mapext=0+0+1.134+0.85&mapsize=600+449&layers=countries+departam_ln&map_countries_class_size=10
Here's the layer definition, though I've also tried this on other layers:
LAYER # paises
NAME countries
DATA countries
GROUP "political"
STATUS OFF
TYPE LINE
CLASS
NAME "Paises"
SYMBOL "line5"
COLOR 0 0 0
SIZE 2
END
METADATA
wmstitle "Paises"
wms_order "1"
meta_href "/mapserv/mapache/data/ciatadm.html"
END
PROJECTION
"proj=latlong"
"ellps=intl"
"no_defs"
END
END
I tried it using browse mode, but I got an error: "mapserv(): Web
application error. No template provided". I don't have a template file
because I'm using the Landview/javascript framework.
Thanks!
-Emilio
PS. My unofficial ("pre-release") MapServer application is here:
http://geo.garrobo.org/mapache/eng/ecosist_ind.html
