[Mapserver-users] ECW not showing below certain scale
Delfos, Jacob
jacob.delfos at maunsell.com
Tue Jun 29 05:33:44 EDT 2004
will check when I am back from holidays
thanks,
Jacob
-----Original Message-----
To: Delfos, Jacob
Cc: Frank Warmerdam; mapserver-users at lists.gis.umn.edu
Sent: 6/26/2004 2:37 AM
Subject: Re: [Mapserver-users] ECW not showing below certain scale
I have put a new version of mapserver 4.3 (current CVS) build with GDAL
1.2.1 at
http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html
(llok at the end of the page for the developpment verion). Let me know
if it solves the ECW issue.
Later,
Frank Warmerdam wrote:
> Delfos, Jacob wrote:
>> Hi All,
>> I've been running into a little problem with mapserver 4.2, which I
>> was also experiencing in Chameleon 1.99; when I zoom in quite far on
>> the map (holding an ecw image), the map doesn't show up. It keeps
>> trying to load, but nothing comes, suggesting it got stuck somewhere.
>> CPU activity is initially at maximum for a few seconds (as normal
when
>> loading the map) but then drops while the map doesn't show (I'm
>> loading the map in the browser on the server itself). The mapserv
>> process won't allow itself to get killed either.
>> If I simply replace my mapserv.exe file with one of version 4.0, the
>> problem is gone. Of course the map takes quite a few seconds to show,
>> which is normal when zooming close on an ECW, but it does show.
>> I've tried this quite a few times in different browsers, but the map
>> never shows at that scale when the ECW is in there. I have tried
>> different mapfiles with different ECW's as well. Has the mechanism to
>> display the ECW changed? It seems that as soon as I reach a
resolution
>> where I go beyond the ECW resolution (1pixel:1pixel) it dies.
> Jacob,
> I was able to reproduce a problem with ECW supersampling when
assertions
> are turned on in GDAL 1.2.0. I have just issued a GDAL 1.2.1 with
this
> issue
> fixed, and suggested to Assefa that he upgrade to that as time
permits.
> I am not absolutely positive if that is your problem or not.
> I suspect you are seeing differences between MapServer 4.0 and 4.2
because
> MapServer 4.2 tries to use "dataset" level io calls when available.
This
> allows reading red, green and blue in one pass against ECW for
instance,
> resulting in better performance. However, it uses different code
paths
> which may have different issues.
> So ... if and when new binaries are available with GDAL 1.2.1 I would
> suggest you try MapServer 4.2 again. In the meantime you could just
set an
> appropriate MINSCALE so the ECW would stop rendering when
supersampled,
> or switch back to the build that works.
> Finally, I will once again strongly suggest that folks running into
> problems
> like this try and reproduce it at the commandline with shp2img and
> appropriate
> extent and debug options. This often results in much more meaningful
error
> messages than you get on in a web application.
> Best regards,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
