[Mapserver-users] Help with example error
TOH CZ
cz_toh at yahoo.com
Mon Mar 1 09:30:07 EST 2004
When I try to run the tutorials that uses fonts with a
Win32 pre-compiled binary, it always return the follow
errors
msGetLabelSize(): TrueType Font error. Could not
find/open font
MAP
NAME EX2.1_
IMAGETYPE png
EXTENT 201621.496941 -294488.285333
1425518.020722 498254.511514 # LAEA
#EXTENT -97.5 41.619778 -82.122902 49.38562
# Geographic
SIZE 400 300
SHAPEPATH "data"
SYMBOLSET "symbols/symbols35.sym"
FONTSET "C:/Program Files/Apache
Group/Apache2/htdocs/tutorial/fonts/fonts.list"
WEB
TEMPLATE 'example2-1.html'
IMAGEPATH '/C:/Program Files/Apache
Group/Apache2/htdocs/tmp/'
IMAGEURL 'C:/Program Files/Apache
END
PROJECTION
# This is Lambert Azimuthal Equal-Area projection
for the
# Continental U.S.
# "proj=laea"
# "ellps=clrk66"
# "lat_0=45"
# "lon_0=-100"
# Alternatively, you can specify an EPSG code.
# This is the EPSG code for
# Lambert Azimuthal Equal-Area projection for the
U.S.
"init=epsg:2163"
END
# Start of LAYER DEFINITIONS
LAYER # States polygon layer begins here
NAME states
DATA states_ugl
STATUS OFF
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION 'land'
SYMBOL 0
COLOR 232 232 232
END
END # States polygon layer ends here
LAYER # MODIS raster layer begins here
NAME modis
DATA
"raster/mod09a12003161_ugl_ll_idxa.tif"
STATUS DEFAULT
TYPE RASTER
OFFSITE 70 74 66
PROJECTION
"init=epsg:4326"
END
END # MODIS raster layer ends here
LAYER # LandSat WMS map from JPL (or from USGS)
NAME LandSat
TYPE RASTER
OFFSITE 0 0 0
STATUS OFF
CONNECTIONTYPE WMS
CONNECTION
"http://wms.jpl.nasa.gov/wms.cgi?REQUEST=map&LAYERS=us_landsat7&STYLES=&FORMAT=png&TRANSPARENT=true"
#CONNECTION
"http://gisdata.usgs.net/servlet/com.esri.wms.Esrimap?ServiceName=USGS_WMS_LANDSAT7&VERSION=1.0.0&REQUEST=map&Layers=LANDSAT7&SRS=EPSG:4326&REASPECT=false&Format=png&"
METADATA
"wms_title" "LandSat"
"wms_name" "us_landsat7"
"wms_server_version" "1.0.0"
"wms_srs" "epsg:4326"
"wms_format" "image/png"
#"wms_title" "US_Landsat7"
# "wms_srs" "epsg:4326"
# "wms_connectiontimeout" "1000"
END
PROJECTION
"init=epsg:4326"
END
END # LandSat WMS image ends here
LAYER # Hydrography layer begins here
NAME hydro
TYPE POLYGON
STATUS DEFAULT
DATA hydrop_ugl
PROJECTION
"init=epsg:4326"
END
TOLERANCE 3
CLASSITEM 'FEATURE'
CLASS
NAME 'Lakes'
EXPRESSION /(^B|^C|^L|^R)./
COLOR 72 64 254
END # CLASS
CLASS
NAME 'Rivers'
EXPRESSION 'Stream'
COLOR 136 128 255
END # CLASS
CLASS
NAME 'Wetlands'
EXPRESSION 'Swamp or Marsh'
COLOR 195 252 255
OUTLINECOLOR 195 252 255
SYMBOL 'circle'
SIZE 0
END # CLASS
END # LAYER
LAYER # ROADS LAYER
NAME cty_roads
GROUP roads
TYPE LINE
STATUS DEFAULT
DATA roads_ugl
MAXSCALE 750000
PROJECTION
"init=epsg:4326"
END
HEADER 'templates/roads_header.html'
FOOTER 'templates/roads_footer.html'
TOLERANCE 5
CLASSITEM 'CLASS1'
CLASS
NAME 'Minor Arterial Roads'
EXPRESSION '3'
COLOR 165 165 165
END # CLASS
CLASS
EXPRESSION '4'
COLOR 210 210 210
END # CLASS
END # ROADS LAYER
LAYER # state highways begin here
NAME state_hwy
GROUP roads
MAXSCALE 1500000
STATUS DEFAULT
DATA roads_ugl
TYPE LINE
FILTERITEM 'CLASS1'
FILTER '2'
CLASS
NAME 'Principal Arterial Roads'
STYLE
COLOR 255 0 0
SIZE 1
SYMBOL 'circle'
END
END
PROJECTION
"init=epsg:4326"
END
END # highways
LAYER # interstate highways begin here
NAME interstate
GROUP roads
# MAXSCALE 22500000
STATUS DEFAULT
DATA roads_ugl
TYPE LINE
FILTERITEM 'CLASS1'
FILTER '1'
CLASS
NAME "Interstate Hwy."
STYLE
COLOR 128 0 0
# SIZE 2
# SYMBOL 'circle'
END
END
PROJECTION
"init=epsg:4326"
END
END # highways
LAYER # States line layer begins here
NAME states
DATA states_ugl
STATUS DEFAULT
TYPE LINE
PROJECTION
"init=epsg:4326"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION 'land'
SYMBOL 'line5'
COLOR 64 64 64
SIZE 1
END
END # States line layer ends here
LAYER
NAME roads_anno
GROUP roads
MAXSCALE 750000
STATUS DEFAULT
DATA roads_ugl
TYPE ANNOTATION
LABELITEM "SIGN"
CLASSITEM "CLASS1"
CLASS
EXPRESSION "3"
STYLE
COLOR 0 0 0 # dummy color
SYMBOL 'symbols/sthwy.png'
END
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION "2"
STYLE
SYMBOL 'symbols/ushwy.png'
END
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
PROJECTION
"init=epsg:4326"
END
END # highway annotation
LAYER
NAME roads_anno1
GROUP roads
STATUS DEFAULT
DATA roads_ugl
TYPE ANNOTATION
LABELITEM "SIGN"
CLASSITEM "CLASS1"
CLASS
EXPRESSION "1"
STYLE
SYMBOL 'symbols/interstate.png'
END
LABEL
MINFEATURESIZE 20
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 255 255 255
END
END
PROJECTION
"init=epsg:4326"
END
END
LAYER # States label layer begins here
NAME states
DATA states_ugl
STATUS DEFAULT
TYPE ANNOTATION
PROJECTION
"init=epsg:4326"
END
CLASSITEM "CLASS"
LABELITEM "STATE"
CLASS
EXPRESSION 'land'
COLOR -1 -1 -1
LABEL
COLOR 132 31 31
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT arial-bold SIZE 12
ANTIALIAS TRUE
POSITION CL
PARTIALS FALSE
MINDISTANCE 300
BUFFER 0
END # end of label
END # end of class
END # States label layer ends here
# End of LAYER DEFINITIONS
END # end of map file
When I remove the TYPE,FONT and SIZE attribute the map
is able to load perfectly but with it it returns the
error
The front file contains everything it needs to load
Can someone help please?
___________________________________________________________
Yahoo! Messenger - Communicate instantly..."Ping"
your friends today! Download Messenger Now
http://uk.messenger.yahoo.com/download/index.html
