[Mapserver-users] Researching the Capabilities of MapServer
Flavio Hendry
flavio at tydac.ch
Tue Mar 2 12:13:13 EST 2004
Hi Jean François
> The buffer you're pretty much going to NEED a Java applet, as I've
> never heard of any way to draw circles in a browser ...
no problem doing that with javascript too, somehow the same way we did
the distance thing (which we gave to Dan and is the one used in
chameleon ...) ... on slow machines it is a bit slow however ... (we
have as well polygon select, rectangle select and so on ...).
and for the statistis stuff, that might be worth a look (using OWT
chart quite a bit)- in french for you! :-) ...
http://www.ch03.ch/fr/geopolitics/abstimmungen/abstimmungen.php
We did as well an application for the swiss department of statistcs,
doing all the selection stuff above in connection with OWT chart too,
however it's internal only and we are not allowed to publish details
yet.
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
############ Mit freundlichen Gruessen / Kind Regards
############ mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
