[Mapserver-users] libgd was not built with FreeType font support
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Mon Mar 1 09:50:30 EST 2004
When trying to run $MapFile->draw() I'm getting:
"Warning: [MapServer Error]: msGetLabelSize(): libgd was not built with FreeType font support in ..."
The strange fact is that my CGI applications runs OK.
I have MapServer CGI as
MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
configured with :
$ ./configure --prefix=/usr/local --without-jpeg --without-tiff --with-freetype --with-zlib --with-png --with-gd --with-xpm=/usr/X11R6/lib --with-pdf=/usr/local/mapserver-linux-distro/deps/PDFlib-5.0.2-Linux/bind/c --with-eppl --with-proj --with-threads --with-ogr --with-gdal --without-ming --with-wfs --with-wfsclient --with-wms -with-wmsclient --with-curl-config --with-curl --enable-ignore-missing-data --disable-debug --with-php=/usr/local/mapserver-linux-distro/deps/php-4.3.4
and PHPMapScript as
configured with:
$ ./configure --prefix=/usr/local --without-aolserver --without-apache --enable-cli --disable-embed --without-nsapi --without-pi3web --without-servlet --enable-cgi --enable-force-cgi-redirect --enable-fastcgi --disable-debug --with-config-file-path=/etc --enable-safe-mode --disable-sigchild --enable-magic-quotes --enable-short-tags --disable-ipv6 --without-openssl --with-zlib --without-bz2 --enable-calendar --without-cpdflib --with-jpeg=/usr/local/bin --with-tiff=/usr/local/lib --without-crack --with-curl=/usr/local/lib --without-cyrus --without-db --enable-dba --without-gdbm --without-ndbm --without-dba --without-db3 --without-db2 --without-dbm --without-cdb --with-inifile --without-flatfile --enable-dbase --enable-dbx --enable-dio --without-dom --enable-exif --without-fbsql --without-fdftk --disable-filepro --without-fribidi--enable-ftp --with-cg=/usr --with-jpeg-dir=/usr/local/bin --with-freetype=/usr/lib --with-t1lib=/usr/include --with-gd --enable-gd-native-ttf --disable-gd-jis-conv --with-gettext=/usr/lib --without-gmp --without-hwapi --without-hyperwave --without-imap --without-kerberos --without-imap-ssl --without-informix --without-ingress --without-interbase --without-ircg --without-java --without-ldap --enable-mbstring --disable-mregex --without-libmbfl --without-mcal --without-mcrypt --without-mcve --with-mhash --with-mime-magic--without-mnogosearch --without-msession --without-msql --without-mssql --with-mysql --without-ncurses --without-oci8 --without-adabas --without-sapdb --without-solid --without-ibm-db2 --without-empress --without-birdstep --without-custom-odbc --without-iodbc --without-esoob --without-unixODBC --without-dbmaker --without-oracle --disable-overload --without-ovrimos --disable-pcntl --with-pcre-regex --without-pfpro --with-pgsql=/usr --disable-posix --without-pspell --without-qtdom --without-libedit --without-readline --without-recode --enable-session --with-mm --disable-shmop --without-snmp --disable-ucd-snmp-hack --enable-sockets --with-regex=system --without-swf --without
-sybase --without-sybase-ct --disable-sysvmsg --disable-sysvsem --disable-sysvshm --disable-tokenizer --disable-wddx --enable-xml --disable-xslt --without-sablot-js --without-yaz --disable-yp --without-zip --with-pear
thanks in advance.
http://www.consultoria.eti.br
## Projeto MapServer Brasil - http://mapserver.cttmar.univali.br ##
***Fim da Mensagem / End of Message ***
