[Mapserver-users] libgd was not built with FreeType font support
Zak James
zak-ms at hoppsan.org
Mon Mar 1 12:20:01 EST 2004
You need to recompile php to use your system's gd library rather than
it's own internal one (which is the default). Mapserver has picked up
your system gd, which is why cgi mode works. In php's configure, you
need to do --with-gd=<path to system gd>
Watch configure's output closely to make sure it's actually getting the
correct gd - if there's a problem it grabs the one in it's own ext
folder.
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
On Mar 1, 2004, at 9:50 AM, Eduardo Patto Kanegae wrote:
> When trying to run $MapFile->draw() I'm getting:
> "Warning: [MapServer Error]: msGetLabelSize(): libgd was not built
> with FreeType font support in ..."
> The strange fact is that my CGI applications runs OK.
> I have MapServer CGI as
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> configured with :
> $ ./configure --prefix=/usr/local --without-jpeg --without-tiff
> --with-freetype --with-zlib --with-png --with-gd
> --with-xpm=/usr/X11R6/lib
> --with-pdf=/usr/local/mapserver-linux-distro/deps/PDFlib-5.0.2-Linux/
> bind/c --with-eppl --with-proj --with-threads --with-ogr --with-gdal
> --without-ming --with-wfs --with-wfsclient --with-wms -with-wmsclient
> --with-curl-config --with-curl --enable-ignore-missing-data
> --disable-debug
> --with-php=/usr/local/mapserver-linux-distro/deps/php-4.3.4
> and PHPMapScript as
> configured with:
> $ ./configure --prefix=/usr/local --without-aolserver
> --without-apache --enable-cli --disable-embed --without-nsapi
> --without-pi3web --without-servlet --enable-cgi
> --enable-force-cgi-redirect --enable-fastcgi --disable-debug
> --with-config-file-path=/etc --enable-safe-mode --disable-sigchild
> --enable-magic-quotes --enable-short-tags --disable-ipv6
> --without-openssl --with-zlib --without-bz2 --enable-calendar
> --without-cpdflib --with-jpeg=/usr/local/bin
> --with-tiff=/usr/local/lib --without-crack --with-curl=/usr/local/lib
> --without-cyrus --without-db --enable-dba --without-gdbm
> --without-ndbm --without-dba --without-db3 --without-db2 --without-dbm
> --without-cdb --with-inifile --without-flatfile --enable-dbase
> --enable-dbx --enable-dio --without-dom --enable-exif --without-fbsql
> --without-fdftk --disable-filepro --without-fribidi--enable-ftp
> --with-cg=/usr --with-jpeg-dir=/usr/local/bin --with-freetype=/usr/lib
> --with-t1lib=/usr/include --with-gd --enable-gd-native-ttf --dis!
> able-gd-jis-conv --with-gettext=/usr/lib --without-gmp
> --without-hwapi --without-hyperwave --without-imap --without-kerberos
> --without-imap-ssl --without-informix --without-ingress
> --without-interbase --without-ircg --without-java --without-ldap
> --enable-mbstring --disable-mregex --without-libmbfl --without-mcal
> --without-mcrypt --without-mcve --with-mhash
> --with-mime-magic--without-mnogosearch --without-msession
> --without-msql --without-mssql --with-mysql --without-ncurses
> --without-oci8 --without-adabas --without-sapdb --without-solid
> --without-ibm-db2 --without-empress --without-birdstep
> --without-custom-odbc --without-iodbc --without-esoob
> --without-unixODBC --without-dbmaker --without-oracle
> --disable-overload --without-ovrimos --disable-pcntl --with-pcre-regex
> --without-pfpro --with-pgsql=/usr --disable-posix --without-pspell
> --without-qtdom --without-libedit --without-readline --without-recode
> --enable-session --with-mm --disable-shmop --without-snmp
> --disable-ucd-!
> snmp-hack --enable-sockets --with-regex=system --without-swf --without
> -sybase --without-sybase-ct --disable-sysvmsg --disable-sysvsem
> --disable-sysvshm --disable-tokenizer --disable-wddx --enable-xml
> --disable-xslt --without-sablot-js --without-yaz --disable-yp
> --without-zip --with-pear
> thanks in advance.
> http://www.consultoria.eti.br
> ## Projeto MapServer Brasil - http://mapserver.cttmar.univali.br ##
> ***Fim da Mensagem / End of Message ***
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
