[Mapserver-users] Problem with dbox DHTML displaying layers
Ellenbecker, Larry
LEllenbecker at co.winnebago.wi.us
Mon Mar 1 12:48:14 EST 2004
Hi!
I'm having a problem displaying my shapefile layers when trying to us
the dbox DHTML interface. I can get the demo to work but cannot get my
shapefiles to work unless I reproject the files. Here is what I
have found.
My shapefiles are in Wisconsin Stateplane NAD83 Southern Zone 4803 (feet).
I can get the demo to work with my date if I change the projection to UTM
or Nad83 (meters). The map extent for one of my NAD83 (feet) shapefiles
would typically be:
NAD83 (feet)
EXTENT 2198000 675000 2450000 840000
In UTM the extent would be:
EXTENT 348550 4860950 387890 4900550
I had come to the conclusion that the JavaScript code that converts
the pixel offset to real coordinates for zoom was not able to calculate
when the min-x is greater the the min-y. I don't know if this is a cbe
issue
or if there is some other explanation.
I thought about using Proj.4 reprojection but I could only find parameters
for
State Plane NAD 83 (meters). I don't want to reproject all my shapefiles so
for the moment I'm stuck. I would really like to use dbox so any insights
into
this problem would be greatly appreciated.
Regards,
Larry L. Ellenbecker
Winnebago County WI
