[Mapserver-users] MapServer and postgis using views
Hubert Fröhlich
hubert.froehlich at bvv.bayern.de
Tue Mar 2 01:56:47 EST 2004
Hello list,
I use MapServer 4.0 / 4.0.1) with postgis. I have defined a layer in a
static mapfile (no mapscript at all)
LAYER
CONNECTIONTYPE postgis
NAME "flstpgx_poly"
CONNECTION "dbname=ax host=va45c28 user=postgres"
DATA "pgpoly from (select * from v_axflst_geom ) as foo using unique
obnr using SRID=31494"
HEADER "q_flstpgx_header.html"
FOOTER "q_DEFAULT_footer.html"
STATUS OFF
TYPE POLYGON
MAXSCALE 200000
# FILTER "gemeinde > 0"
CLASS
NAME "Flurstücke"
# EXPRESSION "gemschl > 0"
TEMPLATE "q_flstpgx.html"
COLOR -1 -1 -1
OUTLINECOLOR 200 0 0
END
END
v_axflst_geom is a view on a table axflst defining the subset of the
attributes which I REALLY need.
I have defined a template for browsing and querying the layer.
Browsing is fine. Queries, however, result in an empty html message output.
When I do not work with a view but read directly from the table with the
mapfile entry
DATA "pgpoly from axflst"
the query seems fine.
Did I miss something in dealing with views?
Greetings,
Hubert
Dr.-Ing. Hubert Fröhlich
Bezirksfinanzdirektion München
Alexandrastr. 3, D-80538 München, GERMANY
Tel. :+49 (0)89 / 2190 - 2980
Fax :+49 (0)89 / 2190 - 2997
hubert dot froehlich at bvv dot bayern dot de
