[Mapserver-users] Mapserver compiled and source download
mountainduo at mho.com
Tue Mar 2 12:53:49 EST 2004
I guess what i hoped to get is a download file that had the source and
also the compiled objects so then i can create a windows dll so i can use
java.
i get the mapscript_wrap.c to compile but then when i try to link the
compiled object i get a lot of undifined references to mapserver
functions. This is where i need the compiled mapserver library files so i
can link and create my dll. I had thought i had seen somewhere that there
was a mapserver.lib file but i could be wrong.
can you post this zip file?
thanks a lot
>> mapserver.lib ???
>> I never saw it before! please be sure the filename u want.
>> best.
>> Eduardo Patto Kanegae
>> http://www.consultoria.eti.br
>> ## Projeto MapServer Brasil - http://mapserver.cttmar.univali.br ##
>> ***Fim da Mensagem / End of Message ***
>> On Sat, 28 Feb 2004 15:23:30 -0700 (MST), <mountainduo at mho.com>
>> escreveu:
>>> De: <mountainduo at mho.com>
>>> Data: Sat, 28 Feb 2004 15:23:30 -0700 (MST)
>>> Para: <eduardo at consultoria.eti.br>
>>> Assunto: Re: [Mapserver-users] Mapserver compiled and source download
>>> Thank you for your reply. I have downloaded a few of the files but
>>> still can't find the mapserver.lib file. Can you tell me which file i
>>> should download?
>>> thanks again,
>>> will
>>> > http://www2.dmsolutions.ca/webtools/dl/
>>> > On Sat, 28 Feb 2004 13:41:30 -0700 (MST), <mountainduo at mho.com>
>>> escreveu:
>>> >> Data: Sat, 28 Feb 2004 13:41:30 -0700 (MST)
>>> >> Para: <mapserver-users at lists.gis.umn.edu>
>>> >> Assunto: [Mapserver-users] Mapserver compiled and source download
>>> >> Hello,
>>> >> Is there somewhere where i can download the source and compiled
>>> version together? I am having problems compiling mapserver and all i
>>> really need is the mapserver.lib file (and any other library
>>> files).
>>> >> thank you for your help,
>>> >> will
>>> >> _______________________________________________
>>> >> Mapserver-users mailing list
>>> >> Mapserver-users at lists.gis.umn.edu
>>> >> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
