[Mapserver-users] Mapserver compiled and source download
Yewondwossen Assefa
assefa at dmsolutions.ca
Tue Mar 2 13:33:53 EST 2004
Hi there,
I have put a mapserver lib that comes from a build on my machine
(mapserver cvs from a couple of days ago) at
www2.dmsolutions.ca/tmp/mapservlib.zip.
Not sure if you need more that this file. Le me know.
Later,
mountainduo at mho.com wrote:
> I guess what i hoped to get is a download file that had the source and
> also the compiled objects so then i can create a windows dll so i can use
> java.
> i get the mapscript_wrap.c to compile but then when i try to link the
> compiled object i get a lot of undifined references to mapserver
> functions. This is where i need the compiled mapserver library files so i
> can link and create my dll. I had thought i had seen somewhere that there
> was a mapserver.lib file but i could be wrong.
> can you post this zip file?
> thanks a lot
>>>mapserver.lib ???
>>>I never saw it before! please be sure the filename u want.
>>>best.
>>>Eduardo Patto Kanegae
>>>http://www.consultoria.eti.br
>>>## Projeto MapServer Brasil - http://mapserver.cttmar.univali.br ##
>>>***Fim da Mensagem / End of Message ***
>>>On Sat, 28 Feb 2004 15:23:30 -0700 (MST), <mountainduo at mho.com>
>>>escreveu:
>>>>De: <mountainduo at mho.com>
>>>>Data: Sat, 28 Feb 2004 15:23:30 -0700 (MST)
>>>>Para: <eduardo at consultoria.eti.br>
>>>>Assunto: Re: [Mapserver-users] Mapserver compiled and source download
>>>>Thank you for your reply. I have downloaded a few of the files but
>>>>still can't find the mapserver.lib file. Can you tell me which file i
>>>>should download?
>>>>thanks again,
>>>>will
>>>>>http://www2.dmsolutions.ca/webtools/dl/
>>>>>On Sat, 28 Feb 2004 13:41:30 -0700 (MST), <mountainduo at mho.com>
>>>>escreveu:
>>>>>>Data: Sat, 28 Feb 2004 13:41:30 -0700 (MST)
>>>>>>Para: <mapserver-users at lists.gis.umn.edu>
>>>>>>Assunto: [Mapserver-users] Mapserver compiled and source download
>>>>>>Hello,
>>>>>>Is there somewhere where i can download the source and compiled
>>>>version together? I am having problems compiling mapserver and all i
>>>>really need is the mapserver.lib file (and any other library
>>>>files).
>>>>>>thank you for your help,
>>>>>>will
>>>>>>_______________________________________________
>>>>>>Mapserver-users mailing list
>>>>>>Mapserver-users at lists.gis.umn.edu
>>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
