[Mapserver-users] Mapserver compiled and source download
mountainduo at mho.com
Tue Mar 2 13:51:36 EST 2004
Awesome, thanks.
Now my linker is complaining about the gd library. Can you post the gd
windows library as well?
thanks!
> Hi there,
> I have put a mapserver lib that comes from a build on my machine
> (mapserver cvs from a couple of days ago) at
> www2.dmsolutions.ca/tmp/mapservlib.zip.
> Not sure if you need more that this file. Le me know.
> Later,
> mountainduo at mho.com wrote:
>> I guess what i hoped to get is a download file that had the source and
>> also the compiled objects so then i can create a windows dll so i can
>> use java.
>> i get the mapscript_wrap.c to compile but then when i try to link the
>> compiled object i get a lot of undifined references to mapserver
>> functions. This is where i need the compiled mapserver library files
>> so i can link and create my dll. I had thought i had seen somewhere
>> that there was a mapserver.lib file but i could be wrong.
>> can you post this zip file?
>> thanks a lot
>>>>mapserver.lib ???
>>>>I never saw it before! please be sure the filename u want.
>>>>best.
>>>>Eduardo Patto Kanegae
>>>>http://www.consultoria.eti.br
>>>>## Projeto MapServer Brasil - http://mapserver.cttmar.univali.br ##
>>>>***Fim da Mensagem / End of Message ***
>>>>On Sat, 28 Feb 2004 15:23:30 -0700 (MST), <mountainduo at mho.com>
>>>> escreveu:
>>>>>De: <mountainduo at mho.com>
>>>>>Data: Sat, 28 Feb 2004 15:23:30 -0700 (MST)
>>>>>Para: <eduardo at consultoria.eti.br>
>>>>>Assunto: Re: [Mapserver-users] Mapserver compiled and source
>>>>> download
>>>>>Thank you for your reply. I have downloaded a few of the files but
>>>>> still can't find the mapserver.lib file. Can you tell me which file
>>>>> i should download?
>>>>>thanks again,
>>>>>will
>>>>>>http://www2.dmsolutions.ca/webtools/dl/
>>>>>>On Sat, 28 Feb 2004 13:41:30 -0700 (MST), <mountainduo at mho.com>
>>>>>escreveu:
>>>>>>>Data: Sat, 28 Feb 2004 13:41:30 -0700 (MST)
>>>>>>>Para: <mapserver-users at lists.gis.umn.edu>
>>>>>>>Assunto: [Mapserver-users] Mapserver compiled and source download
>>>>>>>Hello,
>>>>>>>Is there somewhere where i can download the source and compiled
>>>>>version together? I am having problems compiling mapserver and all i
>>>>> really need is the mapserver.lib file (and any other library
>>>>>files).
>>>>>>>thank you for your help,
>>>>>>>will
>>>>>>>_______________________________________________
>>>>>>>Mapserver-users mailing list
>>>>>>>Mapserver-users at lists.gis.umn.edu
>>>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
