[Mapserver-users] SLD Problems
Bart van den Eijnden
bartvde at xs4all.nl
Fri Mar 5 07:35:36 EST 2004
Hi Stefan,
below is an SLD document which works for me on Mapserver. I have just
created this SLD with a test version of Studio, the new product by DM
Solutions for creating SLD documents.
Note that the NAME is all uppercase in my generated SLD, I don't know why
this is the case, because it is not according to spec as far as I know.
You could try changing that in your SLD. Also, is your Mapserver binary
new enough for this stuff?
Best regards,
Bart
<StyledLayerDescriptor version="1.0.0">
<NamedLayer>
<NAME>Gemeentes</NAME>
<UserStyle>
<FeatureTypeStyle>
<Rule>
<Filter><PropertyIsEqualTo><PropertyName>GEMNAAM</PropertyName><Literal>Deurne</Literal></PropertyIsEqualTo></Filter>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#8f0000</CssParameter>
<GraphicFill>
<Graphic>
<Size>1</Size>
<Mark>
<WellKnownName>cross</WellKnownName>
<Fill>
</Fill>
</Mark>
</Graphic>
</GraphicFill>
</Fill>
</PolygonSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
Best regards,
Bart
On Fri, 05 Mar 2004 10:28:53 +0100, Stefan Schwarzer
<stefan.schwarzer at grid.unep.ch> wrote:
> Hi there,
> I am trying to change the layer properties via SLD. Although I think I
> setup everything correctly, it just doesn't want to work. Could anyone
> perhaps give me a hint on what I do wrong? See below the URL, the SLD and
> the MAP file. The map displays, but not with the desired changes in fill
> and stroke.
> Thanks for any help,
> Stefan
> http://localhost/cgi-bin/mapserv_41.exe?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&map=E:/inetpub/wwwroot/wms_maps/wms.map&layers=boundaries&SLD=http//localhost/wms_maps/sld.xml
> <NamedLayer>
> <Name>boundaries</Name>
> <UserStyle>
> <Title>xxx</Title>
> <FeatureTypeStyle>
> <Rule>
> <PolygonSymbolizer>
> <Fill>
> <CssParameter
> name="fill">#0000ff</CssParameter>
> </Fill>
> <Stroke>
> <CssParameter
> name="stroke">#ff0000</CssParameter>
> </Stroke>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> # Start of map file
> NAME boundaries
> STATUS ON
> SIZE 600 300
> EXTENT -180 -90 180 90
> UNITS DD
> SHAPEPATH "data"
> IMAGETYPE PNG
> FONTSET etc/fonts.txt
> # Projection definition ---------------------
> PROJECTION
> "init=epsg:4326"
> proj=latlong
> ellps=WGS84
> END
> # End Projection definition ---------------------
> # Web definition ---------------------
> WEB
> HEADER demo_header.html
> TEMPLATE demo.html
> FOOTER demo_footer.html
> IMAGEPATH '../temp/'
> IMAGEURL 'temp/'
> METADATA
> "wms_title" "boundaries"
> "wms_onlineresource"
> "http://my_server/cgi-bin/mapserv_41.exe?map=E:/inetpub/wwwroot/wms_maps/wms.map?"
> END
> END
> # End Web definition ---------------------
> LAYER
> NAME boundaries
> TYPE POLYGON
> STATUS ON
> DATA boundaries
> DUMP TRUE
> CLASSITEM CNTRY_NAME
> CLASS
> NAME 'boundaries'
> OUTLINECOLOR 0 0 0
> COLOR 100 100 100
> TEMPLATE 'dummy'
> END
> METADATA
> wms_title "boundaries"
> END
> END
> END # Map File
> _______________________________________
> Stefan Schwarzer
> Consultant on GEO
> UNEP/DEWA/GRID-Geneva
> Chemin des Anemones 11
> CH - 1219 Chatelaine
> Switzerland
> Tel: (+41) 22.917.83.49
> Fax: (+41) 22.917.80.29
> Email: stefan.schwarzer at grid.unep.ch
> Internet: http://geodata.grid.unep.ch/
