[Mapserver-users] SLD Problems
Stefan Schwarzer
stefan.schwarzer at grid.unep.ch
Fri Mar 5 07:47:47 EST 2004
--=====================_107998234==.ALT
Content-Type: text/plain; charset="us-ascii"; format=flowed
Bart,
thanks for the script. Don't see so much difference though to mine. Could
you perhaps send as well the map file, or at least the necessary parts, so
that I can compare that as well? The uppercase didn't succeed...
And what's the Studio? Haven't heard about it and haven't seen it either on
their web site.
Thanks for your help,
Stefan
>Hi Stefan,
>below is an SLD document which works for me on Mapserver. I have just
>created this SLD with a test version of Studio, the new product by DM
>Solutions for creating SLD documents.
>Note that the NAME is all uppercase in my generated SLD, I don't know why
>this is the case, because it is not according to spec as far as I know.
>You could try changing that in your SLD. Also, is your Mapserver binary
>new enough for this stuff?
>Best regards,
>Bart
><StyledLayerDescriptor version="1.0.0">
><NamedLayer>
><NAME>Gemeentes</NAME>
><UserStyle>
><FeatureTypeStyle>
><Rule>
><Filter><PropertyIsEqualTo><PropertyName>GEMNAAM</PropertyName><Literal>Deurne</Literal></PropertyIsEqualTo></Filter>
><PolygonSymbolizer>
><Fill>
><CssParameter name="fill">#8f0000</CssParameter>
><GraphicFill>
><Graphic>
><Size>1</Size>
><Mark>
><WellKnownName>cross</WellKnownName>
><Fill>
></Fill>
></Mark>
></Graphic>
></GraphicFill>
></Fill>
></PolygonSymbolizer>
></Rule>
></FeatureTypeStyle>
></UserStyle>
></NamedLayer>
></StyledLayerDescriptor>
>Best regards,
>Bart
>On Fri, 05 Mar 2004 10:28:53 +0100, Stefan Schwarzer
><stefan.schwarzer at grid.unep.ch> wrote:
>>Hi there,
>>I am trying to change the layer properties via SLD. Although I think I
>>setup everything correctly, it just doesn't want to work. Could anyone
>>perhaps give me a hint on what I do wrong? See below the URL, the SLD and
>>the MAP file. The map displays, but not with the desired changes in fill
>>and stroke.
>>Thanks for any help,
>>Stefan
>>http://localhost/cgi-bin/mapserv_41.exe?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&map=E:/inetpub/wwwroot/wms_maps/wms.map&layers=boundaries&SLD=http//localhost/wms_maps/sld.xml
>> <NamedLayer>
>> <Name>boundaries</Name>
>> <UserStyle>
>> <Title>xxx</Title>
>> <FeatureTypeStyle>
>> <Rule>
>> <PolygonSymbolizer>
>> <Fill>
>> <CssParameter
>>name="fill">#0000ff</CssParameter>
>> </Fill>
>> <Stroke>
>> <CssParameter
>>name="stroke">#ff0000</CssParameter>
>> </Stroke>
>> </Rule>
>> </FeatureTypeStyle>
>> </UserStyle>
>> </NamedLayer>
>># Start of map file
>>NAME boundaries
>> STATUS ON
>> SIZE 600 300
>> EXTENT -180 -90 180 90
>> UNITS DD
>> SHAPEPATH "data"
>> IMAGETYPE PNG
>> FONTSET etc/fonts.txt
>> # Projection definition ---------------------
>> PROJECTION
>> "init=epsg:4326"
>> proj=latlong
>> ellps=WGS84
>> END
>> # End Projection definition ---------------------
>> # Web definition ---------------------
>> WEB
>> HEADER demo_header.html
>> TEMPLATE demo.html
>> FOOTER demo_footer.html
>> IMAGEPATH '../temp/'
>> IMAGEURL 'temp/'
>> METADATA
>> "wms_title" "boundaries"
>> "wms_onlineresource"
>>"http://my_server/cgi-bin/mapserv_41.exe?map=E:/inetpub/wwwroot/wms_maps/wms.map?"
>> END
>> END
>> # End Web definition ---------------------
>> LAYER
>> NAME boundaries
>> TYPE POLYGON
>> STATUS ON
>> DATA boundaries
>> DUMP TRUE
>> CLASSITEM CNTRY_NAME
>> CLASS
>> NAME 'boundaries'
>> OUTLINECOLOR 0 0 0
>> COLOR 100 100 100
>> TEMPLATE 'dummy'
>> END
>> METADATA
>> wms_title "boundaries"
>> END
>> END
>>END # Map File
>> _______________________________________
>> Stefan Schwarzer
>> Consultant on GEO
>> UNEP/DEWA/GRID-Geneva
>> Chemin des Anemones 11
>> CH - 1219 Chatelaine
>> Switzerland
>> Tel: (+41) 22.917.83.49
>> Fax: (+41) 22.917.80.29
>> Email: stefan.schwarzer at grid.unep.ch
>> Internet: http://geodata.grid.unep.ch/
Stefan Schwarzer
Consultant on GEO
Switzerland
Content-Type: text/html; charset="us-ascii"
<html>
<body>
<font size=3>Bart,<br><br>
so that I can compare that as well? The uppercase didn't
succeed...<br><br>
on their web site.<br><br>
Thanks for your help,<br><br>
Stefan<br><br>
<br><br>
<blockquote type=cite class=cite cite>Hi Stefan,<br><br>
Solutions for creating SLD documents.<br><br>
new enough for this stuff?<br><br>
Best regards,<br>
Bart<br><br>
<StyledLayerDescriptor version="1.0.0"><br>
<NamedLayer><br>
<NAME>Gemeentes</NAME><br>
<UserStyle><br>
<FeatureTypeStyle><br>
<Rule><br>
<Filter><PropertyIsEqualTo><PropertyName>GEMNAAM</PropertyName><Literal>Deurne</Literal></PropertyIsEqualTo></Filter><br>
<PolygonSymbolizer><br>
<Fill><br>
<CssParameter
name="fill">#8f0000</CssParameter><br>
<GraphicFill><br>
<Graphic><br>
<Size>1</Size><br>
<Mark><br>
<WellKnownName>cross</WellKnownName><br>
<Fill><br>
<CssParameter
</Fill><br>
</Mark><br>
</Graphic><br>
</GraphicFill><br>
</Fill><br>
</PolygonSymbolizer><br>
</Rule><br>
</FeatureTypeStyle><br>
</UserStyle><br>
</NamedLayer><br>
</StyledLayerDescriptor><br><br>
Best regards,<br>
Bart<br><br>
<stefan.schwarzer at grid.unep.ch> wrote:<br><br>
<blockquote type=cite class=cite cite>Hi there,<br><br>
I<br>
anyone<br>
and<br>
fill<br>
and stroke.<br><br>
Thanks for any help,<br><br>
Stefan<br><br>
<br>
<a href="http://localhost/cgi-bin/mapserv_41.exe?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&map=E:/inetpub/wwwroot/wms_maps/wms.map&layers=boundaries&SLD=http//localhost/wms_maps/sld.xml" eudora="autourl">http://localhost/cgi-bin/mapserv_41.exe?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&map=E:/inetpub/wwwroot/wms_maps/wms.map&layers=boundaries&SLD=http//localhost/wms_maps/sld.xml</a><br><br>
<br><br>
<NamedLayer><br>
<Name>boundaries</Name><br>
<UserStyle><br>
<Title>xxx</Title><br>
<Rule><br>
<Fill><br>
<CssParameter<br>
name="fill">#0000ff</CssParameter><br>
</Fill><br>
<Stroke><br>
<CssParameter<br>
name="stroke">#ff0000</CssParameter><br>
</Stroke><br>
</Rule><br>
</UserStyle><br>
</NamedLayer><br>
<br><br>
#<br>
# Start of map file<br>
#<br><br>
NAME boundaries<br>
STATUS ON<br>
SIZE 600 300<br>
EXTENT -180 -90 180
90<br>
UNITS DD<br>
SHAPEPATH
"data"<br>
IMAGETYPE PNG<br>
FONTSET
etc/fonts.txt<br><br>
<br><br>
---------------------<br><br>
PROJECTION<br>
"init=epsg:4326"<br>
proj=latlong<br>
ellps=WGS84<br>
END<br><br>
# End Projection
definition ---------------------<br><br>
<br><br>
# Web definition
WEB<br>
HEADER demo_header.html<br>
TEMPLATE demo.html<br>
FOOTER demo_footer.html<br><br>
IMAGEPATH '../temp/'<br>
IMAGEURL 'temp/'<br><br>
METADATA<br>
"wms_title" "boundaries"<br>
"wms_onlineresource"<br>
"<a href="http://my_server/cgi-bin/mapserv_41.exe?map=E:/inetpub/wwwroot/wms_maps/wms.map" eudora="autourl">http://my_server/cgi-bin/mapserv_41.exe?map=E:/inetpub/wwwroot/wms_maps/wms.map</a>?"<br>
END<br>
END<br><br>
<br><br>
LAYER<br>
NAME boundaries<br>
TYPE POLYGON<br>
STATUS ON<br>
DATA boundaries<br>
DUMP TRUE<br>
CLASSITEM CNTRY_NAME<br>
CLASS<br>
NAME 'boundaries'<br>
OUTLINECOLOR 0 0 0<br>
COLOR 100 100 100<br>
TEMPLATE 'dummy'<br>
END<br>
METADATA<br>
wms_title "boundaries"<br>
END<br>
END<br><br>
END # Map File<br><br>
<br><br>
<br>
_______________________________________<br><br>
Stefan Schwarzer<br>
Consultant on
GEO<br><br>
UNEP/DEWA/GRID-Geneva<br>
Chemin des Anemones
11<br>
CH - 1219
Chatelaine<br>
Switzerland<br><br>
Tel: (+41)
22.917.83.49<br>
Fax: (+41)
22.917.80.29<br><br>
Email:
stefan.schwarzer at grid.unep.ch<br>
Internet:
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/</a><br>
_______________________________________</blockquote><br><br>
<br>
-- <br>
</blockquote>
<x-sigsep><p></x-sigsep>
<x-tab> </x-tab>_______________________________________<br><br>
</font><font size=2><x-tab> </x-tab><b>Stefan
Schwarzer<br>
</b><x-tab> </x-tab>Consultant
on GEO<br><br>
<x-tab> </x-tab>UNEP/DEWA/GRID-Geneva<br>
<x-tab> </x-tab>Chemin des
Anemones 11<br>
<x-tab> </x-tab>CH - 1219
Chatelaine<br>
<x-tab> </x-tab>Switzerland<br><br>
<x-tab> </x-tab>Tel: (+41)
22.917.83.49<br>
<x-tab> </x-tab>Fax: (+41)
<x-tab> </x-tab>Email:
<x-tab> </x-tab>Internet:
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/<br>
</a></font><font size=3><x-tab> </x-tab>_______________________________________</font></body>
</html>
--=====================_107998234==.ALT--
