[Mapserver-users] SLD Problems
Bart van den Eijnden
bartvde at xs4all.nl
Fri Mar 5 07:59:21 EST 2004
Hi Stefan,
don't think the problem is in the MAP file, but here it goes.
As for Studio, it is an OGC-centric application that allows you to create
classes and styles for use in SLD documents. I am only doing a sort of
beta test (0.99 version), but for sure if you ask DM Solutions, you can
have a beta test copy as well. This would simplify the process you are
going through now.
Best regards,
Bart
MAP
EXTENT 10000 305000 280000 619000
IMAGECOLOR 255 255 255
IMAGETYPE png
INTERLACE TRUE
SHAPEPATH "../data"
SIZE 860 590
STATUS ON
TRANSPARENT FALSE
UNITS METERS
NAME "DEMO"
OUTPUTFORMAT
NAME png
MIMETYPE image/png
DRIVER GD/PNG
EXTENSION png
IMAGEMODE PC256
TRANSPARENT FALSE
END
PROJECTION
"init=EPSG:28992"
END
LEGEND
KEYSIZE 18 12
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 89
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS ON
#TEMPLATE
"d:/ms4w/maplab-2.1-rc1/htdocs/mapbrowser/legend_template.html"
END
QUERYMAP
COLOR 255 0 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
SCALEBAR
BACKGROUNDCOLOR 0 0 0
COLOR 255 255 255
INTERVALS 5
LABEL
SIZE SMALL
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION UL
END
OUTLINECOLOR 0 0 0
POSITION LL
SIZE 150 5
STATUS OFF
STYLE 0
UNITS KILOMETERS
END
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
WMS_TITLE "Gemeentes mapserver WMS"
WMS_ABSTRACT "UMN MapServer Gemeentekaart"
WMS_ACCESSCONSTRAINTS none
WMS_SRS "EPSG:28992"
WFS_TITLE "Gemeentes mapserver WFS"
WFS_ONLINERESOURCE
"http://www.vz.geodan.nl:1111/cgi-bin/mapserv.exe?map=/ms4w/apps/general/map/gemeentes.map"
WFS_SRS "EPSG:28992"
OWS_SCHEMAS_LOCATION "http://ogc.dmsolutions.ca"
END
END
LAYER
DATA "Nlge_r98"
METADATA
WMS_TITLE "Gemeentes"
WMS_ABSTRACT "Gemeentes via UMN Mapserver"
WFS_TITLE "Gemeentes"
END
NAME "Gemeentes"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE POLYGON
DUMP TRUE
TEMPLATE "blank.html"
UNITS METERS
CLASS
NAME "Foreign Lands"
STYLE
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 255 0 0
SIZE 1
SYMBOL 0
END
END
END
END
On Fri, 05 Mar 2004 13:47:47 +0100, Stefan Schwarzer
<stefan.schwarzer at grid.unep.ch> wrote:
> Bart,
> thanks for the script. Don't see so much difference though to mine. Could
> you perhaps send as well the map file, or at least the necessary parts,
> so
> that I can compare that as well? The uppercase didn't succeed...
> And what's the Studio? Haven't heard about it and haven't seen it either
> on
> their web site.
> Thanks for your help,
> Stefan
>> Hi Stefan,
>> below is an SLD document which works for me on Mapserver. I have just
>> created this SLD with a test version of Studio, the new product by DM
>> Solutions for creating SLD documents.
>> Note that the NAME is all uppercase in my generated SLD, I don't know
>> why
>> this is the case, because it is not according to spec as far as I know.
>> You could try changing that in your SLD. Also, is your Mapserver binary
>> new enough for this stuff?
>> Best regards,
>> Bart
>> <StyledLayerDescriptor version="1.0.0">
>> <NamedLayer>
>> <NAME>Gemeentes</NAME>
>> <UserStyle>
>> <FeatureTypeStyle>
>> <Rule>
>> <Filter><PropertyIsEqualTo><PropertyName>GEMNAAM</PropertyName><Literal>Deurne</Literal></PropertyIsEqualTo></Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> <CssParameter name="fill">#8f0000</CssParameter>
>> <GraphicFill>
>> <Graphic>
>> <Size>1</Size>
>> <Mark>
>> <WellKnownName>cross</WellKnownName>
>> <Fill>
>> </Fill>
>> </Mark>
>> </Graphic>
>> </GraphicFill>
>> </Fill>
>> </PolygonSymbolizer>
>> </Rule>
>> </FeatureTypeStyle>
>> </UserStyle>
>> </NamedLayer>
>> </StyledLayerDescriptor>
>> Best regards,
>> Bart
>> On Fri, 05 Mar 2004 10:28:53 +0100, Stefan Schwarzer
>>> Hi there,
>>> I am trying to change the layer properties via SLD. Although I think I
>>> setup everything correctly, it just doesn't want to work. Could anyone
>>> perhaps give me a hint on what I do wrong? See below the URL, the SLD
>>> and
>>> the MAP file. The map displays, but not with the desired changes in
>>> fill
>>> and stroke.
>>> Thanks for any help,
>>> Stefan
>>> http://localhost/cgi-bin/mapserv_41.exe?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&map=E:/inetpub/wwwroot/wms_maps/wms.map&layers=boundaries&SLD=http//localhost/wms_maps/sld.xml
>>> <NamedLayer>
>>> <Name>boundaries</Name>
>>> <UserStyle>
>>> <Title>xxx</Title>
>>> <FeatureTypeStyle>
>>> <Rule>
>>> <PolygonSymbolizer>
>>> <Fill>
>>> <CssParameter
>>> name="fill">#0000ff</CssParameter>
>>> </Fill>
>>> <Stroke>
>>> <CssParameter
>>> name="stroke">#ff0000</CssParameter>
>>> </Stroke>
>>> </Rule>
>>> </FeatureTypeStyle>
>>> </UserStyle>
>>> </NamedLayer>
>>> # Start of map file
>>> NAME boundaries
>>> STATUS ON
>>> SIZE 600 300
>>> EXTENT -180 -90 180 90
>>> UNITS DD
>>> SHAPEPATH "data"
>>> IMAGETYPE PNG
>>> FONTSET etc/fonts.txt
>>> # Projection definition ---------------------
>>> PROJECTION
>>> "init=epsg:4326"
>>> proj=latlong
>>> ellps=WGS84
>>> END
>>> # End Projection definition ---------------------
>>> # Web definition ---------------------
>>> WEB
>>> HEADER demo_header.html
>>> TEMPLATE demo.html
>>> FOOTER demo_footer.html
>>> IMAGEPATH '../temp/'
>>> IMAGEURL 'temp/'
>>> METADATA
>>> "wms_title" "boundaries"
>>> "wms_onlineresource"
>>> "http://my_server/cgi-bin/mapserv_41.exe?map=E:/inetpub/wwwroot/wms_maps/wms.map?"
>>> END
>>> END
>>> # End Web definition ---------------------
>>> LAYER
>>> NAME boundaries
>>> TYPE POLYGON
>>> STATUS ON
>>> DATA boundaries
>>> DUMP TRUE
>>> CLASSITEM CNTRY_NAME
>>> CLASS
>>> NAME 'boundaries'
>>> OUTLINECOLOR 0 0 0
>>> COLOR 100 100 100
>>> TEMPLATE 'dummy'
>>> END
>>> METADATA
>>> wms_title "boundaries"
>>> END
>>> END
>>> END # Map File
>>> _______________________________________
>>> Stefan Schwarzer
>>> Consultant on GEO
>>> UNEP/DEWA/GRID-Geneva
>>> Chemin des Anemones 11
>>> CH - 1219 Chatelaine
>>> Switzerland
>>> Tel: (+41) 22.917.83.49
>>> Fax: (+41) 22.917.80.29
>>> Email: stefan.schwarzer at grid.unep.ch
>>> Internet: http://geodata.grid.unep.ch/
> Stefan Schwarzer
> Consultant on GEO
> Switzerland
