[Mapserver-users] SLD Problems
Dave McIlhagga
dmcilhagga at dmsolutions.ca
Mon Mar 8 15:05:13 EST 2004
Hi Guys,
Just for clarification -- "Studio" remains pretty much an internal
development piece at the moment. We're still uncertain how we plan to
distribute it (although you can count on seeing it in some way soon
enough!!) For that matter, we're not even sure what we'll be calling it
yet. ;)
It's a pretty cool environment for styling remote data sources via SLD
and also for managing local data layers through MapServer and a Mapfile.
We're currently trying to decide if it should be released as a
stand-alone utility, or only bundled within a future 3.0 release of MapLab.
At the moment though, we've only made it accessible to a relatively
small group of people as we don't have the capacity at the moment to
support it beyond a few individuals. We'll follow up with much more
information in the months ahead.
and if you're really keen to learn more about it ... come out to the
next MapServer user meeting in Ottawa - I'm sure there will be
discussions on it then! ;)
http://www.omsug.ca/osgis2004/index.html
Dave
Bart van den Eijnden wrote:
> Hi Stefan,
> don't think the problem is in the MAP file, but here it goes.
> As for Studio, it is an OGC-centric application that allows you to
> create classes and styles for use in SLD documents. I am only doing a
> sort of beta test (0.99 version), but for sure if you ask DM Solutions,
> you can have a beta test copy as well. This would simplify the process
> you are going through now.
> Best regards,
> Bart
> MAP
> EXTENT 10000 305000 280000 619000
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> INTERLACE TRUE
> SHAPEPATH "../data"
> SIZE 860 590
> STATUS ON
> TRANSPARENT FALSE
> UNITS METERS
> NAME "DEMO"
> OUTPUTFORMAT
> NAME png
> MIMETYPE image/png
> DRIVER GD/PNG
> EXTENSION png
> IMAGEMODE PC256
> TRANSPARENT FALSE
> END
> PROJECTION
> "init=EPSG:28992"
> END
> LEGEND
> KEYSIZE 18 12
> KEYSPACING 5 5
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 89
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> END
> POSITION LL
> STATUS ON
> #TEMPLATE
> "d:/ms4w/maplab-2.1-rc1/htdocs/mapbrowser/legend_template.html"
> END
> QUERYMAP
> COLOR 255 0 0
> SIZE -1 -1
> STATUS OFF
> STYLE HILITE
> END
> SCALEBAR
> BACKGROUNDCOLOR 0 0 0
> COLOR 255 255 255
> INTERVALS 5
> LABEL
> SIZE SMALL
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> POSITION UL
> END
> OUTLINECOLOR 0 0 0
> POSITION LL
> SIZE 150 5
> STATUS OFF
> STYLE 0
> UNITS KILOMETERS
> END
> WEB
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> WMS_TITLE "Gemeentes mapserver WMS"
> WMS_ABSTRACT "UMN MapServer Gemeentekaart"
> WMS_ACCESSCONSTRAINTS none
> WMS_SRS "EPSG:28992"
> WFS_TITLE "Gemeentes mapserver WFS"
> WFS_ONLINERESOURCE
> "http://www.vz.geodan.nl:1111/cgi-bin/mapserv.exe?map=/ms4w/apps/general/map/gemeentes.map"
> WFS_SRS "EPSG:28992"
> OWS_SCHEMAS_LOCATION "http://ogc.dmsolutions.ca"
> END
> END
> LAYER
> DATA "Nlge_r98"
> METADATA
> WMS_TITLE "Gemeentes"
> WMS_ABSTRACT "Gemeentes via UMN Mapserver"
> WFS_TITLE "Gemeentes"
> END
> NAME "Gemeentes"
> SIZEUNITS PIXELS
> STATUS ON
> TOLERANCE 0
> TOLERANCEUNITS PIXELS
> TYPE POLYGON
> DUMP TRUE
> TEMPLATE "blank.html"
> UNITS METERS
> CLASS
> NAME "Foreign Lands"
> STYLE
> MAXSIZE 100
> MINSIZE 1
> OUTLINECOLOR 255 0 0
> SIZE 1
> SYMBOL 0
> END
> END
> END
> END
> On Fri, 05 Mar 2004 13:47:47 +0100, Stefan Schwarzer
> <stefan.schwarzer at grid.unep.ch> wrote:
>> Bart,
>> thanks for the script. Don't see so much difference though to mine. Could
>> you perhaps send as well the map file, or at least the necessary
>> parts, so
>> that I can compare that as well? The uppercase didn't succeed...
>> And what's the Studio? Haven't heard about it and haven't seen it
>> either on
>> their web site.
>> Thanks for your help,
>> Stefan
>>> Hi Stefan,
>>> below is an SLD document which works for me on Mapserver. I have just
>>> created this SLD with a test version of Studio, the new product by DM
>>> Solutions for creating SLD documents.
>>> Note that the NAME is all uppercase in my generated SLD, I don't know
>>> why
>>> this is the case, because it is not according to spec as far as I know.
>>> You could try changing that in your SLD. Also, is your Mapserver binary
>>> new enough for this stuff?
>>> Best regards,
>>> Bart
>>> <StyledLayerDescriptor version="1.0.0">
>>> <NamedLayer>
>>> <NAME>Gemeentes</NAME>
>>> <UserStyle>
>>> <FeatureTypeStyle>
>>> <Rule>
>>> <Filter><PropertyIsEqualTo><PropertyName>GEMNAAM</PropertyName><Literal>Deurne</Literal></PropertyIsEqualTo></Filter>
>>> <PolygonSymbolizer>
>>> <Fill>
>>> <CssParameter name="fill">#8f0000</CssParameter>
>>> <GraphicFill>
>>> <Graphic>
>>> <Size>1</Size>
>>> <Mark>
>>> <WellKnownName>cross</WellKnownName>
>>> <Fill>
>>> </Fill>
>>> </Mark>
>>> </Graphic>
>>> </GraphicFill>
>>> </Fill>
>>> </PolygonSymbolizer>
>>> </Rule>
>>> </FeatureTypeStyle>
>>> </UserStyle>
>>> </NamedLayer>
>>> </StyledLayerDescriptor>
>>> Best regards,
>>> Bart
>>> On Fri, 05 Mar 2004 10:28:53 +0100, Stefan Schwarzer
>>>> Hi there,
>>>> I am trying to change the layer properties via SLD. Although I think I
>>>> setup everything correctly, it just doesn't want to work. Could anyone
>>>> perhaps give me a hint on what I do wrong? See below the URL, the
>>>> SLD and
>>>> the MAP file. The map displays, but not with the desired changes in
>>>> fill
>>>> and stroke.
>>>> Thanks for any help,
>>>> Stefan
>>>> http://localhost/cgi-bin/mapserv_41.exe?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&map=E:/inetpub/wwwroot/wms_maps/wms.map&layers=boundaries&SLD=http//localhost/wms_maps/sld.xml
>>>> <NamedLayer>
>>>> <Name>boundaries</Name>
>>>> <UserStyle>
>>>> <Title>xxx</Title>
>>>> <FeatureTypeStyle>
>>>> <Rule>
>>>> <PolygonSymbolizer>
>>>> <Fill>
>>>> <CssParameter
>>>> name="fill">#0000ff</CssParameter>
>>>> </Fill>
>>>> <Stroke>
>>>> <CssParameter
>>>> name="stroke">#ff0000</CssParameter>
>>>> </Stroke>
>>>> </Rule>
>>>> </FeatureTypeStyle>
>>>> </UserStyle>
>>>> </NamedLayer>
>>>> # Start of map file
>>>> NAME boundaries
>>>> STATUS ON
>>>> SIZE 600 300
>>>> EXTENT -180 -90 180 90
>>>> UNITS DD
>>>> SHAPEPATH "data"
>>>> IMAGETYPE PNG
>>>> FONTSET etc/fonts.txt
>>>> # Projection definition ---------------------
>>>> PROJECTION
>>>> "init=epsg:4326"
>>>> proj=latlong
>>>> ellps=WGS84
>>>> END
>>>> # End Projection definition ---------------------
>>>> # Web definition ---------------------
>>>> WEB
>>>> HEADER demo_header.html
>>>> TEMPLATE demo.html
>>>> FOOTER demo_footer.html
>>>> IMAGEPATH '../temp/'
>>>> IMAGEURL 'temp/'
>>>> METADATA
>>>> "wms_title" "boundaries"
>>>> "wms_onlineresource"
>>>> "http://my_server/cgi-bin/mapserv_41.exe?map=E:/inetpub/wwwroot/wms_maps/wms.map?"
>>>> END
>>>> END
>>>> # End Web definition ---------------------
>>>> LAYER
>>>> NAME boundaries
>>>> TYPE POLYGON
>>>> STATUS ON
>>>> DATA boundaries
>>>> DUMP TRUE
>>>> CLASSITEM CNTRY_NAME
>>>> CLASS
>>>> NAME 'boundaries'
>>>> OUTLINECOLOR 0 0 0
>>>> COLOR 100 100 100
>>>> TEMPLATE 'dummy'
>>>> END
>>>> METADATA
>>>> wms_title "boundaries"
>>>> END
>>>> END
>>>> END # Map File
>>>> _______________________________________
>>>> Stefan Schwarzer
>>>> Consultant on GEO
>>>> UNEP/DEWA/GRID-Geneva
>>>> Chemin des Anemones 11
>>>> CH - 1219 Chatelaine
>>>> Switzerland
>>>> Tel: (+41) 22.917.83.49
>>>> Fax: (+41) 22.917.80.29
>>>> Email: stefan.schwarzer at grid.unep.ch
>>>> Internet: http://geodata.grid.unep.ch/
>> Stefan Schwarzer
>> Consultant on GEO
>> Switzerland
