[Mapserver-users] SLD Problems
Yewondwossen Assefa
assefa at dmsolutions.ca
Fri Mar 5 10:16:00 EST 2004
There is definitly nothing wrong with the your SLD document as it seems
to work with tests data that I have here. I can not see anything wrong
either in your map. Are you using a recent mapserver exe ? There is one
dating froma couple of days on the maptools.org (take the developpment
version)
:http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html.
If you still hav problems, tou can send me directly your map file and
your data and I can setup a test here and see what might be wrong.
Later,
Stefan Schwarzer wrote:
> Hi there,
> I am trying to change the layer properties via SLD. Although I think I
> setup everything correctly, it just doesn't want to work. Could anyone
> perhaps give me a hint on what I do wrong? See below the URL, the SLD
> and the MAP file. The map displays, but not with the desired changes in
> fill and stroke.
> Thanks for any help,
> Stefan
> http://localhost/cgi-bin/mapserv_41.exe?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&map=E:/inetpub/wwwroot/wms_maps/wms.map&layers=boundaries&SLD=http//localhost/wms_maps/sld.xml
> <http://localhost/cgi-bin/mapserv_41.exe?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&map=E:/inetpub/wwwroot/wms_maps/wms.map&layers=boundaries&SLD=http//localhost/wms_maps/sld.xml>
> <StyledLayerDescriptor version="1.0.0">
> <NamedLayer>
> <Name>boundaries</Name>
> <UserStyle>
> <Title>xxx</Title>
> <FeatureTypeStyle>
> <Rule>
> <PolygonSymbolizer>
> <Fill>
> <CssParameter
> name="fill">#0000ff</CssParameter>
> </Fill>
> <Stroke>
> <CssParameter
> name="stroke">#ff0000</CssParameter>
> </Stroke>
> </PolygonSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> # Start of map file
> NAME boundaries
> STATUS ON
> SIZE 600 300
> EXTENT -180 -90 180 90
> UNITS DD
> SHAPEPATH "data"
> IMAGETYPE PNG
> FONTSET etc/fonts.txt
> # Projection definition ---------------------
> PROJECTION
> "init=epsg:4326"
> proj=latlong
> ellps=WGS84
> END
> # End Projection definition ---------------------
> # Web definition ---------------------
> WEB
> HEADER demo_header.html
> TEMPLATE demo.html
> FOOTER demo_footer.html
> IMAGEPATH '../temp/'
> IMAGEURL 'temp/'
> METADATA
> "wms_title" "boundaries"
> "wms_onlineresource"
> "http://my_server/cgi-bin/mapserv_41.exe?map=E:/inetpub/wwwroot/wms_maps/wms.map?"
> END
> END
> # End Web definition ---------------------
> LAYER
> NAME boundaries
> TYPE POLYGON
> STATUS ON
> DATA boundaries
> DUMP TRUE
> CLASSITEM CNTRY_NAME
> CLASS
> NAME 'boundaries'
> OUTLINECOLOR 0 0 0
> COLOR 100 100 100
> TEMPLATE 'dummy'
> END
> METADATA
> wms_title "boundaries"
> END
> END
> END # Map File
> _______________________________________
> *Stefan Schwarzer
> * Consultant on GEO
> UNEP/DEWA/GRID-Geneva
> Chemin des Anemones 11
> CH - 1219 Chatelaine
> Switzerland
> Tel: (+41) 22.917.83.49
> Fax: (+41) 22.917.80.29
> Email: stefan.schwarzer at grid.unep.ch
> Internet: http://geodata.grid.unep.ch/
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
