[Mapserver-users] Projection problem
Michael Smith
msmith at sanangelompo.org
Fri Mar 5 09:53:21 EST 2004
I'm no expert on mapserver either, but you may need to change your UNITS
from DD to METERS or FEET.
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of snow 77
Sent: Thursday, March 04, 2004 3:05 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Projection problem
I am new to the MapServer and i have a typical newbie question.
I try to get am map on the web with only one shapefile as a layer. The
shapefile is from the given extent and i think i define the right projection
parameters. But the output map is quite distorted. Where ist the mistake?
Here my mapfile:
MAP
NAME "test"
STATUS ON
EXTENT 13.563817 46.2695106622074 16.166907714098 48.1749556
#EXTENT 389334.69 5124995.01 586750.69 5336404.45
SIZE 530 350
SHAPEPATH "../../../Inetpub/wwwroot/imdas/data"
FONTSET "../../../Inetpub/wwwroot/imdas/fonts/fonts.list"
IMAGECOLOR 255 255 255
UNITS DD
RESOLUTION 72
PROJECTION
"proj=utm"
"zone=1"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs "
"north"
"init=epsg:32601"
END
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
END
#order7
LAYER
NAME "aut6__________a7"
STATUS ON
DATA "../../../../Inetpub/wwwroot/demo/data/aut6__________a7"
LABELITEM "NAME"
CLASS
TEMPLATE void
COLOR 255 255 204
OUTLINECOLOR 200 200 200
LABEL
COLOR 132 31 31
COLOR 16 125 65
TYPE TRUETYPE
FONT arial-bold
SIZE 10
ANTIALIAS TRUE
POSITION AUTO
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
END # end of label
END
TYPE POLYGON
UNITS DD
END
END
Can anyone help me? Thanks a lot!
Sonja
_________________________________________________________________
Die MSN Suche - Kategorien helfen Ihnen dabei, präzise Ergebnisse zu
erhalten. http://search.msn.at/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
