[Mapserver-users] Projection problem
Jason M. Nielsen
jnielsen at aero-graphics.com
Fri Mar 5 12:21:15 EST 2004
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of snow 77
> Sent: Thursday, March 04, 2004 3:05 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Projection problem
> Hi,
> I am new to the MapServer and i have a typical newbie question.
> I try to get am map on the web with only one shapefile as a layer. The
> shapefile is from the given extent and i think i define the right
> projection
> parameters. But the output map is quite distorted. Where ist the mistake?
> Here my mapfile:
> MAP
> NAME "test"
> STATUS ON
> EXTENT 13.563817 46.2695106622074 16.166907714098 48.1749556
> #EXTENT 389334.69 5124995.01 586750.69 5336404.45
> SIZE 530 350
> SHAPEPATH "../../../Inetpub/wwwroot/imdas/data"
> FONTSET "../../../Inetpub/wwwroot/imdas/fonts/fonts.list"
> IMAGECOLOR 255 255 255
> UNITS DD
> RESOLUTION 72
> PROJECTION
> "proj=utm"
> "zone=1"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs "
> "north"
> "init=epsg:32601"
> END
Looks like based on the projection you have listed (32601) your .map file UNITS
setting should be METERS. DD I think would only be used with for instance
epsg:4326.
This mail sent through IMP: http://horde.org/imp/
