[Mapserver-users] POSTGIS problem
Wai-ho Wong
wawong at ucsd.edu
Fri Mar 5 17:19:13 EST 2004
To whom it might be concerned,
I am the postGIS user in UC San Diego. I have the postGIS working fine and
the mapserver can take the input of shapefile. Both of them are the most
updated versions. But when I try to map using postGIS, I have the unkown
internal error or blank picture output.
The following is the map file.
MAP
IMAGETYPE PNG
SIZE 600 600
EXTENT 2951122.40634836 9972524.19586431 3272632.96527259 10243868.741275
# Geographic coordinates
IMAGECOLOR 255 255 255
LAYER
CONNECTIONTYPE postgis
NAME "railroad"
CONNECTION "user=willy password=goodwill dbname=mydb host=geon01.sdsc.edu port=7531"
DATA "the_geom FROM railroad"
STATUS DEFAULT
TYPE POLYGON
CLASS
STYLE
COLOR 0 0 0
END
END
END
END
Thank you for your help.
Willy
