[Mapserver-users] POSTGIS problem
Swaminathan, Gayathri
gayathri at ou.edu
Fri Mar 5 18:07:33 EST 2004
Hi:
Why are you using port 7531 instead of the default 5432? Is there a
specific intented reason?
Gayathri
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Wai-ho Wong
> Sent: Friday, March 05, 2004 4:19 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] POSTGIS problem
> To whom it might be concerned,
> I am the postGIS user in UC San Diego. I have the postGIS
> working fine and the mapserver can take the input of
> shapefile. Both of them are the most updated versions. But
> when I try to map using postGIS, I have the unkown internal
> error or blank picture output.
> The following is the map file.
> MAP
> IMAGETYPE PNG
> SIZE 600 600
> EXTENT 2951122.40634836 9972524.19586431 3272632.96527259
> 10243868.741275 # Geographic coordinates IMAGECOLOR 255 255 255
> LAYER
> CONNECTIONTYPE postgis
> NAME "railroad"
> CONNECTION "user=willy password=goodwill
> dbname=mydb host=geon01.sdsc.edu port=7531"
> DATA "the_geom FROM railroad"
> STATUS DEFAULT
> TYPE POLYGON
> CLASS
> STYLE
> COLOR 0 0 0
> END
> END
> END
> END
> Thank you for your help.
> Willy
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
