[Mapserver-users] Queryfile
Werner du Plessis
werner at spatialdimension.co.za
Mon Mar 8 01:52:44 EST 2004
Hi Steve,
I struggled with the exact same problem & managed to resolve.
The problem was the "savequery" paramater, you need to set it to nothing after the first queryfile's created. Setting "savequery=false" will still create a queryfile, so you have to set it to "savequery=".
This will allow you to interact with the map while your query results are displayed. To clear the queryresults just set "queryfile=".
Hope this helps.
Regards
Werner du Plessis
