[Mapserver-users] Query by point shape and tile indexes are -1
Will Richardson
willrichardson at teq-services.com
Tue Mar 9 14:26:25 EST 2004
sorry, the problem is that shapeindex is -1 and tileindex is -1 so getShape
returns a null object as it can't find any shape. I am using mapscript for
mapserver 3.6.3 as this is the only version i have found that i can get java
mapscript to work.
my understanding is that the shape and tile index would be set in the layer
after i add a feature but then when i query the layer i do find 1
resultCacheMemberObj but the values in there are -1. How do i fix this?
in the java mapscript version i have, the code you have below is wrapped so
that the java method i call (getShape) does return a shapeObj.
thanks
Quoting Sean Gillies <sgillies at frii.com>:
> On Mar 9, 2004, at 11:45 AM, Will Richardson wrote:
> > Hello,
> > I am trying to do a query after i add a feature to a layer and the
> > shape and
> > tile indexes are -1 so i can't get the shape that was queried. Below
> > is my
> > code in java, if you have any suggestions, please let me know.
> > thanks
> > layerObj layer = map.getLayerByName( "towermark" );
> > layer.setStatus( MapScript.MS_ON );
> > pointObj myHouse = new pointObj();
> > myHouse.setX( -104.06478597176886 );
> > myHouse.setY( 38.46972580576644 );
> > lineObj line = new lineObj();
> > line.add( myHouse );
> > shapeObj shape = new shapeObj( MapScript.MS_SHAPE_POINT );
> > shape.add( line );
> > layer.addFeature( shape );
> > imageObj image = map.draw();
> > pointObj queryPoint = new pointObj();
> > queryPoint.setX( -104.06478597176886 );
> > queryPoint.setY( 38.46972580576644 );
> > int result = layer.queryByPoint( map, queryPoint,
> > MapScript.MS_SINGLE, 10 );
> > System.out.println( "result of query: " + result );
> > System.out.println( "MS_SUCCESS: " + MapScript.MS_SUCCESS
> > System.out.println( "MS_FAILURE: " + MapScript.MS_FAILURE
> > resultCacheObj cache = layer.getResultcache();
> > //prints 1
> > System.out.println( "number of results: " +
> > cache.getNumresults
> > resultCacheMemberObj resultObj = layer.getResult( 0 );
> > System.out.println( "shape index: " +
> > resultObj.getShapeindex() );
> > System.out.println( "tile index: " +
> > resultObj.getTileindex() );
> > System.out.println( "Class index: " +
> > resultObj.getClassindex() );
> > shape = layer.getShape( resultObj.getTileindex(),
> > if ( shape != null )
> > System.out.println( "shape.getNumvalues(): " +
> > shape.getNumvalues() );
> > ______
> Will,
> I think you forgot to ask your question ... you want to know why
> getShape doesn't work as expected?
> You don't say so, but I am assuming you are using a Java mapscript from
> Mapserver 3.x? True? Well, one problem is that getShape doesn't
> return a shapeObj. Your code will have to be something like this:
> shapeObj shape = shapeObj(layer.type);
> layer.getShape(shape, resultObj.getTileindex(),
> resultObj.getShapeindex());
> Hope this helps,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
