[Mapserver-users] Perl Mapscript Dynamic Layer Rendering in 4.01
Simpson, Andrew
Andrew.Simpson at ssc.nasa.gov
Wed Mar 10 10:29:17 EST 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C406B2.08E80BD4
Content-Type: text/plain
Greetings,
We are migrating from MS 3.6.5 to MS 4.01 on a Linux Redhat server.
Using the migration guide, updated the code where necessary (mainly the
styles object changes).
Does anyone have any ideas why the DrawPolygon() function below renders
fine, but the DrawLine() function does not?
The image is rendered with a scalebar, but vector missing.
I also tried a DrawPoint with no success.
Please put me out of my misery!
Thanks,
Drew.
================= start script ======================
#!/usr/bin/perl
use mapscript;
$map = new mapscript::mapObj("test_map.map") || die "Couldn't instantiate
map object:$!<br>\n";
$img = $map->prepareImage();
#DrawPolygon();
DrawLine();
$map->draw();
$map->drawLabelCache($img);
$outfile = 'mapgen.'.time.'.png';
$img->save($outfile);
exit;
sub DrawLine
$layer = new mapscript::layerObj($map);
$layer->{name} = $name;
$layer->{type} = $mapscript::MS_LAYER_LINE;
$layer->{symbolscale} = 1000; # The scale at which symbols and/or text
appear full size.
$layer->{minscale} = 1;
$layer->{labelcache} = $mapscript::MS_ON;
$layer->{labelmaxscale} = 50000;
$class = new mapscript::classObj($layer);
$class->{numstyles} = 1;
$class->{styles}->{minsize} = 40;
$class->{styles}->{maxsize} = 40;
$class->{styles}->{size} = 40;
$class->{styles}->{symbol} = 7;
$class->{styles}->{color}->{red} = 255;
$class->{styles}->{color}->{green} = 255;
$class->{styles}->{color}->{blue} = 255;
$class->{styles}->{outlinecolor}->{red} = 255;
$class->{styles}->{outlinecolor}->{green} = 0;
$class->{styles}->{outlinecolor}->{blue} = 0;
$class->{label}->{color}->{red} = 0;
$class->{label}->{color}->{green} = 255;
$class->{label}->{color}->{blue} = 255;
$class->{label}->{font} = 'arialbd';
$class->{label}->{type} = $mapscript::MS_TRUETYPE;
$class->{label}->{size} = 7;
$class->{label}->{minsize} = 7;
$shape = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE );
$line = new mapscript::lineObj();
$point = new mapscript::pointObj();
#EXTENT 388553.951505 3166053.063199 914513.202293 3691701.38882
$point->{x} = 400000.000000;
$point->{y} = 3200000.000000;
$line->add($point);
$point->{x} = 900000.000000;
$point->{y} = 3600000.000000;
$line->add($point);
$shape->add($line);
$shape->{text} = "TEST";
$shape->draw($map,$layer,$img);
$layer->draw($map, $img);
undef $layer;
sub DrawPolygon
$layer->{type} = $mapscript::MS_LAYER_POLYGON;
appear full size.
$class->{styles}->{minsize} = 4;
$class->{styles}->{maxsize} = 4;
$class->{styles}->{size} = 4;
$shape = new mapscript::shapeObj($mapscript::MS_SHAPE_POLYGON );
$line->add($point);
$line->add($point);
$line->add($point);
$line->add($point);
$line->add($point);
$shape->add($line);
undef $layer;
====================== end script ======================================
====================== start map =======================================
# Start of map file
NAME DYN_TEST
STATUS ON
SIZE 600 600
FONTSET /var/fonts/font_sets
SYMBOLSET /var/symbols/symbolset.sym
UNITS meters
SHAPEPATH "shapes"
IMAGECOLOR 0 0 0
PROJECTION
"proj=utm"
"zone=15"
"ellps=GRS80"
"datum=NAD83"
"units=m"
END
# Start of web interface definition
WEB
HEADER dipx_header.html
TEMPLATE dipx.html
MINSCALE 1000
MAXSCALE 100000000
IMAGEPATH "/var/www/html/scratch/"
IMAGEURL "/scratch/"
LOG "/var/log/mapserver/mapserv.log"
END
# Start of reference map
REFERENCE
SIZE 120 120
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS MILES
INTERVALS 5
STATUS EMBED
END
# Start of layer definitions
END # Map File
======================= end map =========================
Content-Type: text/html
<html>
<head>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=us-ascii">
<meta name=Generator content="Microsoft Word 10 (filtered)">
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=EN-US link=blue vlink=purple>
<div class=Section1>
<p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;
font-family:Arial'>Greetings,</span></font></p>
font-family:Arial'> </span></font></p>
font-family:Arial'>We are migrating from MS 3.6.5 to MS 4.01 on a Linux Redhat
server.</span></font></p>
font-family:Arial'>Using the migration guide, updated the code where necessary
(mainly the styles object changes).</span></font></p>
font-family:Arial'>Does anyone have any ideas why the DrawPolygon() function
below renders fine, but the DrawLine() function does not?</span></font></p>
font-family:Arial'>The image is rendered with a scalebar, but vector missing.</span></font></p>
font-family:Arial'>I also tried a DrawPoint with no success.</span></font></p>
font-family:Arial'>Please put me out of my misery!</span></font></p>
font-family:Arial'>Thanks,</span></font></p>
font-family:Arial'>Drew.</span></font></p>
font-family:Arial'>================= start script ======================</span></font></p>
font-family:Arial'>#!/usr/bin/perl</span></font></p>
font-family:Arial'>use mapscript;</span></font></p>
font-family:Arial'>$map = new mapscript::mapObj("test_map.map") ||
die "Couldn't instantiate map object:$!<br>\n";</span></font></p>
font-family:Arial'>$img = $map->prepareImage();</span></font></p>
font-family:Arial'>#DrawPolygon();</span></font></p>
font-family:Arial'>DrawLine();</span></font></p>
font-family:Arial'>$map->draw();</span></font></p>
font-family:Arial'>$map->drawLabelCache($img);</span></font></p>
font-family:Arial'>$outfile = 'mapgen.'.time.'.png';</span></font></p>
font-family:Arial'>$img->save($outfile);</span></font></p>
font-family:Arial'>exit;</span></font></p>
font-family:Arial'>sub DrawLine</span></font></p>
font-family:Arial'>{</span></font></p>
font-family:Arial'> $layer = new mapscript::layerObj($map);</span></font></p>
font-family:Arial'> $layer->{name} = $name;</span></font></p>
font-family:Arial'> $layer->{type} = $mapscript::MS_LAYER_LINE;</span></font></p>
font-family:Arial'> $layer->{symbolscale} = 1000; # The scale at which
symbols and/or text appear full size.</span></font></p>
font-family:Arial'> $layer->{minscale} = 1;</span></font></p>
font-family:Arial'> $layer->{labelcache} = $mapscript::MS_ON;</span></font></p>
font-family:Arial'> $layer->{labelmaxscale} = 50000;</span></font></p>
font-family:Arial'> $class = new mapscript::classObj($layer); </span></font></p>
font-family:Arial'> $class->{numstyles} = 1;</span></font></p>
font-family:Arial'> $class->{styles}->{minsize} = 40; </span></font></p>
font-family:Arial'> $class->{styles}->{maxsize} = 40; </span></font></p>
font-family:Arial'> $class->{styles}->{size} = 40; </span></font></p>
font-family:Arial'> $class->{styles}->{symbol} = 7;</span></font></p>
font-family:Arial'> $class->{styles}->{color}->{red} = 255;</span></font></p>
font-family:Arial'> $class->{styles}->{color}->{green} = 255;</span></font></p>
font-family:Arial'> $class->{styles}->{color}->{blue} = 255;</span></font></p>
font-family:Arial'> $class->{styles}->{outlinecolor}->{red} = 255;</span></font></p>
font-family:Arial'> $class->{styles}->{outlinecolor}->{green} = 0;</span></font></p>
font-family:Arial'> $class->{styles}->{outlinecolor}->{blue} = 0;</span></font></p>
font-family:Arial'> $class->{label}->{color}->{red} = 0;</span></font></p>
font-family:Arial'> $class->{label}->{color}->{green} = 255;</span></font></p>
font-family:Arial'> $class->{label}->{color}->{blue} = 255;</span></font></p>
font-family:Arial'> $class->{label}->{font} = 'arialbd';</span></font></p>
font-family:Arial'> $class->{label}->{type} = $mapscript::MS_TRUETYPE;</span></font></p>
font-family:Arial'> $class->{label}->{size} = 7;</span></font></p>
font-family:Arial'> $class->{label}->{minsize} = 7;</span></font></p>
font-family:Arial'> $shape = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE
font-family:Arial'> $line = new mapscript::lineObj();</span></font></p>
font-family:Arial'> $point = new mapscript::pointObj();</span></font></p>
font-family:Arial'> #EXTENT 388553.951505 3166053.063199 914513.202293
3691701.38882</span></font></p>
font-family:Arial'> $point->{x} = 400000.000000;</span></font></p>
font-family:Arial'> $point->{y} = 3200000.000000;</span></font></p>
font-family:Arial'> $line->add($point);</span></font></p>
font-family:Arial'> $point->{x} = 900000.000000;</span></font></p>
font-family:Arial'> $point->{y} = 3600000.000000;</span></font></p>
font-family:Arial'> $shape->add($line);</span></font></p>
font-family:Arial'> $shape->{text} = "TEST";</span></font></p>
font-family:Arial'> $shape->draw($map,$layer,$img);</span></font></p>
font-family:Arial'> $layer->draw($map, $img);</span></font></p>
font-family:Arial'> undef $layer;</span></font></p>
font-family:Arial'>}</span></font></p>
font-family:Arial'>sub DrawPolygon</span></font></p>
font-family:Arial'> $layer->{type} = $mapscript::MS_LAYER_POLYGON;</span></font></p>
font-family:Arial'> $class->{styles}->{minsize} = 4; </span></font></p>
font-family:Arial'> $class->{styles}->{maxsize} = 4; </span></font></p>
font-family:Arial'> $class->{styles}->{size} = 4; </span></font></p>
font-family:Arial'> $shape = new mapscript::shapeObj($mapscript::MS_SHAPE_POLYGON
font-family:Arial'> #EXTENT 388553.951505 3166053.063199 914513.202293 3691701.38882</span></font></p>
font-family:Arial'>====================== end script
======================================</span></font></p>
font-family:Arial'>====================== start map
=======================================</span></font></p>
font-family:Arial'># Start of map file</span></font></p>
font-family:Arial'>#</span></font></p>
font-family:Arial'>NAME DYN_TEST</span></font></p>
font-family:Arial'>STATUS ON</span></font></p>
font-family:Arial'>SIZE 600 600</span></font></p>
font-family:Arial'>FONTSET /var/fonts/font_sets</span></font></p>
font-family:Arial'>SYMBOLSET /var/symbols/symbolset.sym</span></font></p>
font-family:Arial'>EXTENT 388553.951505 3166053.063199 914513.202293
font-family:Arial'>UNITS meters</span></font></p>
font-family:Arial'>SHAPEPATH "shapes"</span></font></p>
font-family:Arial'>IMAGECOLOR 0 0 0</span></font></p>
font-family:Arial'>PROJECTION</span></font></p>
font-family:Arial'> "proj=utm"</span></font></p>
font-family:Arial'> "zone=15"</span></font></p>
font-family:Arial'> "ellps=GRS80"</span></font></p>
font-family:Arial'> "datum=NAD83"</span></font></p>
font-family:Arial'> "units=m"</span></font></p>
font-family:Arial'>END</span></font></p>
font-family:Arial'># Start of web interface definition</span></font></p>
font-family:Arial'>WEB</span></font></p>
font-family:Arial'> HEADER dipx_header.html</span></font></p>
font-family:Arial'> TEMPLATE dipx.html</span></font></p>
font-family:Arial'> MINSCALE 1000</span></font></p>
font-family:Arial'> MAXSCALE 100000000</span></font></p>
font-family:Arial'> IMAGEPATH "/var/www/html/scratch/"</span></font></p>
font-family:Arial'> IMAGEURL "/scratch/"</span></font></p>
font-family:Arial'> LOG "/var/log/mapserver/mapserv.log"</span></font></p>
font-family:Arial'># Start of reference map</span></font></p>
font-family:Arial'>REFERENCE</span></font></p>
font-family:Arial'> IMAGE ref_base_zone_15.png</span></font></p>
font-family:Arial'> EXTENT 388553.951505 3166053.063199 914513.202293
font-family:Arial'> SIZE 120 120</span></font></p>
font-family:Arial'> STATUS ON</span></font></p>
font-family:Arial'> COLOR 255 255 255</span></font></p>
font-family:Arial'> OUTLINECOLOR 255 0 0</span></font></p>
font-family:Arial'># Start of legend</span></font></p>
font-family:Arial'>LEGEND</span></font></p>
font-family:Arial'> KEYSIZE 18 12</span></font></p>
font-family:Arial'> LABEL</span></font></p>
font-family:Arial'> TYPE BITMAP</span></font></p>
font-family:Arial'> SIZE MEDIUM</span></font></p>
font-family:Arial'> COLOR 0 0 89</span></font></p>
font-family:Arial'> END</span></font></p>
font-family:Arial'># Start of scalebar</span></font></p>
font-family:Arial'>SCALEBAR</span></font></p>
font-family:Arial'> IMAGECOLOR 255 255 255</span></font></p>
font-family:Arial'> COLOR 0 0 0</span></font></p>
font-family:Arial'> SIZE SMALL</span></font></p>
font-family:Arial'> SIZE 350 5</span></font></p>
font-family:Arial'> BACKGROUNDCOLOR 0 0 0</span></font></p>
font-family:Arial'> OUTLINECOLOR 0 0 0</span></font></p>
font-family:Arial'> UNITS MILES</span></font></p>
font-family:Arial'> INTERVALS 5</span></font></p>
font-family:Arial'> STATUS EMBED</span></font></p>
font-family:Arial'># Start of layer definitions</span></font></p>
font-family:Arial'>END # Map File</span></font></p>
font-family:Arial'>======================= end map =========================</span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C406B2.08E80BD4--
