[Mapserver-users] Perl Mapscript Dynamic Layer Rendering in 4
.01
Simpson, Andrew
Andrew.Simpson at ssc.nasa.gov
Wed Mar 10 13:13:55 EST 2004
No messages in the MS_ERRORFILE.
-----Original Message-----
Sent: Wednesday, March 10, 2004 11:13 AM
To: Simpson, Andrew; 'mapserver-users at lists.gis.umn.edu'
Subject: Re: [Mapserver-users] Perl Mapscript Dynamic Layer Rendering in
4.01
Does turning on debugging help narrow the search?
$ENV{MS_ERRORFILE} = "/var/log/mapserver.log"; # map engine error log
Lowell
The following message was sent by "Simpson, Andrew"
<Andrew.Simpson at ssc.nasa.gov> on Wed, 10 Mar 2004 09:29:17 -0600.
> Greetings,
> We are migrating from MS 3.6.5 to MS 4.01 on a Linux Redhat server.
> Using the migration guide, updated the code where necessary (mainly the
> styles object changes).
> Does anyone have any ideas why the DrawPolygon() function below renders
> fine, but the DrawLine() function does not?
> The image is rendered with a scalebar, but vector missing.
> I also tried a DrawPoint with no success.
> Please put me out of my misery!
> Thanks,
> Drew.
> ================= start script ======================
> #!/usr/bin/perl
> use mapscript;
> $map = new mapscript::mapObj("test_map.map") || die "Couldn't instantiate
> map object:$!<br>\n";
> $img = $map->prepareImage();
> #DrawPolygon();
> DrawLine();
> $map->draw();
> $map->drawLabelCache($img);
> $outfile = 'mapgen.'.time.'.png';
> $img->save($outfile);
> exit;
> sub DrawLine
> $layer = new mapscript::layerObj($map);
> $layer->{name} = $name;
> $layer->{type} = $mapscript::MS_LAYER_LINE;
> $layer->{symbolscale} = 1000; # The scale at which symbols
and/or text
> appear full size.
> $layer->{minscale} = 1;
> $layer->{labelcache} = $mapscript::MS_ON;
> $layer->{labelmaxscale} = 50000;
> $class = new mapscript::classObj($layer);
> $class->{numstyles} = 1;
> $class->{styles}->{minsize} = 40;
> $class->{styles}->{maxsize} = 40;
> $class->{styles}->{size} = 40;
> $class->{styles}->{symbol} = 7;
> $class->{styles}->{color}->{red} = 255;
> $class->{styles}->{color}->{green} = 255;
> $class->{styles}->{color}->{blue} = 255;
> $class->{styles}->{outlinecolor}->{red} = 255;
> $class->{styles}->{outlinecolor}->{green} = 0;
> $class->{styles}->{outlinecolor}->{blue} = 0;
> $class->{label}->{color}->{red} = 0;
> $class->{label}->{color}->{green} = 255;
> $class->{label}->{color}->{blue} = 255;
> $class->{label}->{font} = 'arialbd';
> $class->{label}->{type} = $mapscript::MS_TRUETYPE;
> $class->{label}->{size} = 7;
> $class->{label}->{minsize} = 7;
> $shape = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE );
> $line = new mapscript::lineObj();
> $point = new mapscript::pointObj();
> #EXTENT 388553.951505 3166053.063199 914513.202293 3691701.38882
> $point->{x} = 400000.000000;
> $point->{y} = 3200000.000000;
> $line->add($point);
> $point->{x} = 900000.000000;
> $point->{y} = 3600000.000000;
> $line->add($point);
> $shape->add($line);
> $shape->{text} = "TEST";
> $shape->draw($map,$layer,$img);
> $layer->draw($map, $img);
> undef $layer;
> sub DrawPolygon
> $layer->{type} = $mapscript::MS_LAYER_POLYGON;
and/or text
> appear full size.
> $class->{styles}->{minsize} = 4;
> $class->{styles}->{maxsize} = 4;
> $class->{styles}->{size} = 4;
> $shape = new mapscript::shapeObj($mapscript::MS_SHAPE_POLYGON );
> $line->add($point);
> $line->add($point);
> $line->add($point);
> $line->add($point);
> $line->add($point);
> $shape->add($line);
> undef $layer;
> ====================== end script ======================================
> ====================== start map =======================================
> # Start of map file
> NAME DYN_TEST
> STATUS ON
> SIZE 600 600
> FONTSET /var/fonts/font_sets
> SYMBOLSET /var/symbols/symbolset.sym
> UNITS meters
> SHAPEPATH "shapes"
> IMAGECOLOR 0 0 0
> PROJECTION
> "proj=utm"
> "zone=15"
> "ellps=GRS80"
> "datum=NAD83"
> "units=m"
> END
> # Start of web interface definition
> WEB
> HEADER dipx_header.html
> TEMPLATE dipx.html
> MINSCALE 1000
> MAXSCALE 100000000
> IMAGEPATH "/var/www/html/scratch/"
> IMAGEURL "/scratch/"
> LOG "/var/log/mapserver/mapserv.log"
> END
> # Start of reference map
> REFERENCE
> SIZE 120 120
> STATUS ON
> COLOR 255 255 255
> OUTLINECOLOR 255 0 0
> END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Start of scalebar
> SCALEBAR
> IMAGECOLOR 255 255 255
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> END
> SIZE 350 5
> COLOR 255 255 255
> BACKGROUNDCOLOR 0 0 0
> OUTLINECOLOR 0 0 0
> UNITS MILES
> INTERVALS 5
> STATUS EMBED
> END
> # Start of layer definitions
> END # Map File
> ======================= end map =========================
