[Mapserver-users] itemnquery - hilite multiple results on single
map {Scanned} {Scanned}
Richard Greenwood
rich at greenwoodmap.com
Fri Mar 12 21:19:31 EST 2004
Siki Zoltan wrote:
> Hi,
> On Fri, 12 Mar 2004, Richard Greenwood wrote:
>>If I do an itemnquery that returns 4 results all 4 results are hilited
>>on my map, but I also get 4 maps. My template gets called 4 times. Any
>>way to suppress that so that I just get one map (my template gets gets
>>called once)?
> I had the same headache recently.
> If you add TEMPLATE, HEADER and FOOTER to the definition of the queried
> layer, the template is evaluated for each found element. So I add the
> real template as the HEADER and I add an empty html to TEMPLATE.
> HEADER and FOOTER are evaluated only ones.
> LAYER xxx
> TEMPLATE "emplty.html"
> HEADER "teh real template"
> FOOTER "empty.html"
> END
> I hope it helps you.
> Bye
> Zoltan
Perfect solution! Thanks so much for your help.
Rich
Richard Greenwood
www.greenwoodmap.com
