[Mapserver-users] Wfs-client, no image appears
Shiming Li
sli1 at uni-forst.gwdg.de
Mon Mar 15 10:05:24 EST 2004
This is a multi-part message in MIME format.
--------------080803070702080501070803
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I want to use MapServer as a WFS client, so I compiled with the option
--with-wfsclient.
But there is nothing in the image area. Is there something wrong?
Any sugesstion will be appreciated.
Computer Environment: Linux SuSE 8.2, Mozilla 1.6, MapServer 4.0.1 (or
nightly build),
The output of the mapserv -v is
MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=JPEG
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I added the following lines to .map file
LAYER
NAME "wfslayer"
TYPE POINT
CONNECTIONTYPE WFS
CONNECTION
"http://localhost:8080/geoserver/wfs?version=1.0.0&request=GetFeature&typename=bi"
STATUS ON
#PROJECTION
# "proj=utm"
# "ellps=WGS84"
# "zone=32"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
# END
PROJECTION
"init=epsg:32632"
END
METADATA
"wfs_connectiontimeout" "60" # Default is 30 seconds
"wfs_latlonboundingbox" "-75 45 -70 50" # Area covered by this layer
END
CLASS
SYMBOL 'circle'
COLOR 200 0 0
END
END
In the tmp directory, I found there is a file named
eedd32eaaae2175d51230f211eb9dc9b.tmp.gml (MapServer 4.1 nightly build)
(In MapServer 4.0.1, there is
http___localhost_8080_geoserver_wfs_version_1_0_0_request_GetFeature_typename_
bi_REQUEST_GetFeature_BBOX_3520125_233879_5719007_333736_3539269_014796_5738651_006564.tmp.gml)
Here is the part of content of the .gml
<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs"
xmlns:topp="http:/
/localhost:8080/geoserver/" xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="ht
tp://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://localhost:80
80/geoserver/
http://localhost:8080/geoserver/wfs/DescribeFeatureType?typeName=b
i http://www.opengis.net/wfs
http://localhost:8080/geoserver/data/capabilities/w
fs/1.0.0/WFS-basic.xsd">
<gml:boundedBy>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#27354">
<gml:coordinates decimal="." cs="," ts=" ">3540100,5729300
3540100,5733400
3544600,5733400 3544600,5729300</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<topp:bi fid="bi.1">
<topp:the_geom>
<gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#27354">
">3542800,5731500</gml:coordi
nates>
</gml:Point>
</topp:the_geom>
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
<title></title>
--with-wfsclient. <br>
But there is nothing in the image area. Is there something wrong?<br>
Any sugesstion will be appreciated.<br>
<br>
nightly build), <br>
<br>
The output of the mapserv -v is <br>
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE<br>
<br>
I added the following lines to .map file<br>
LAYER<br>
NAME "wfslayer"<br>
TYPE POINT<br>
CONNECTIONTYPE WFS<br>
CONNECTION
<a class="moz-txt-link-rfc2396E" href="http://localhost:8080/geoserver/wfs?version=1.0.0&request=GetFeature&typename=bi">"http://localhost:8080/geoserver/wfs?version=1.0.0&request=GetFeature&typename=bi"</a><br>
STATUS ON<br>
#PROJECTION<br>
# "proj=utm"<br>
# "ellps=WGS84"<br>
# "zone=32"<br>
# "north"<br>
# "no_defs"<br>
# OR: <br>
# "init=epsg:26915"<br>
# END<br>
PROJECTION<br>
"init=epsg:32632"<br>
END<br>
METADATA<br>
"wfs_connectiontimeout" "60" # Default is 30 seconds<br>
layer<br>
END<br>
CLASS<br>
SYMBOL 'circle'<br>
COLOR 200 0 0<br>
END<br>
END <br>
<br>
In the tmp directory, I found there is a file named<br>
eedd32eaaae2175d51230f211eb9dc9b.tmp.gml (MapServer 4.1 nightly build)<br>
(In MapServer 4.0.1, there is <br>
http___localhost_8080_geoserver_wfs_version_1_0_0_request_GetFeature_typename_<br>
bi_REQUEST_GetFeature_BBOX_3520125_233879_5719007_333736_3539269_014796_5738651_006564.tmp.gml)<br>
<br>
Here is the part of content of the .gml<br>
<?xml version="1.0" encoding="UTF-8"?><br>
<wfs:FeatureCollection xmlns:wfs=<a class="moz-txt-link-rfc2396E" href="http://www.opengis.net/wfs">"http://www.opengis.net/wfs"</a>
xmlns:topp="<a class="moz-txt-link-freetext" href="http:/">http:/</a><br>
/localhost:8080/geoserver/" xmlns:gml=<a class="moz-txt-link-rfc2396E" href="http://www.opengis.net/gml">"http://www.opengis.net/gml"</a>
xmlns:xsi="ht<br>
xsi:schemaLocation="<a class="moz-txt-link-freetext" href="http://localhost:80">http://localhost:80</a><br>
80/geoserver/
<a class="moz-txt-link-freetext" href="http://localhost:8080/geoserver/wfs/DescribeFeatureType?typeName=b">http://localhost:8080/geoserver/wfs/DescribeFeatureType?typeName=b</a><br>
i <a class="moz-txt-link-freetext" href="http://www.opengis.net/wfs">http://www.opengis.net/wfs</a>
<a class="moz-txt-link-freetext" href="http://localhost:8080/geoserver/data/capabilities/w">http://localhost:8080/geoserver/data/capabilities/w</a><br>
fs/1.0.0/WFS-basic.xsd"><br>
<gml:boundedBy><br>
<gml:Box
srsName=<a class="moz-txt-link-rfc2396E" href="http://www.opengis.net/gml/srs/epsg.xml#27354">"http://www.opengis.net/gml/srs/epsg.xml#27354"</a>><br>
3540100,5733400<br>
3544600,5733400 3544600,5729300</gml:coordinates><br>
</gml:Box><br>
</gml:boundedBy><br>
<gml:featureMember><br>
<topp:bi fid="bi.1"><br>
<topp:the_geom><br>
<gml:Point
">3542800,5731500</gml:coordi<br>
nates><br>
</gml:Point><br>
</topp:the_geom><br>
<br>
<br>
<br>
</body>
</html>
--------------080803070702080501070803--
