[Mapserver-users] Retrieving shape extent - Email found in su
bject
Ryan, Adam
ARyan at co.linn.or.us
Mon Mar 15 20:35:05 EST 2004
Steve et al,
When you write "You can also build images based on query results independent
of the query map" do you mean that in each template iteration we can build a
unique image with the [img] tag, or do you mean that in each iteration we
can re-call mapserver using [shpidx] or some other tag and mode=map?
If the answer is the former, could you please elaborate on how that would be
accomplished. I can imagine a result page that includes a little image of
each result accompanying the attribute data, but I can't see how you'd do
that without calling mapserver for each result record.
Thanks,
Adam Ryan
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Monday, March 15, 2004 11:49 AM
To: charlie at im-design.net; mapserver-users at lists.gis.umn.edu
Subject: RE: [SPAM] - Re: [Mapserver-users] Retrieving shape extent - Email
found in subject
Assuming you're using a query map you'd just use the [img] tag to get at the
image. No extra trip necessary. You can also build images based on query
results independent of the query map.
Steve
>>> "Charles D. Van Dusen" <charlie at im-design.net> 3/15/2004 1:16:03 PM
OK (understood)
So, how do I get the map while in non-map mode? Does it require an extra
round-trip to the server or is the image created?
Im working with the 'workshop' demos (specifically the dhtml banding box
demo), which I believe has its template specified as
'itasca_adds_dhtml.html'.
TIA
Charlie
Charlie Van Dusen
Sent: Monday, March 15, 2004 1:15 PM
To: Charles D. Van Dusen; mapserver-users at lists.gis.umn.edu
Subject: [SPAM] - Re: [Mapserver-users] Retrieving shape extent - Email
found in subject
When you're in a ...MAP mode you only get the map, that's the point. However
you can still get a map with in a non-map mode, but you work through a
template instead. Won't that work for you?
Steve
>>> "Charles D. Van Dusen" <charlie at im-design.net> 3/13/2004 11:38:59
AM >>>
Greetings All,
Is it possible to retrieve the extent of a shape selected whil in
'indexquerymap' mode?
So far I have not been able to retrieve anything but the image of the
selected shape. I need to have the extent ([shpext]) as well, but I have
only been able to retrieve it in 'indexquery' mode.
Any ideas
Thanks
Charlie
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
