[SPAM] - Re: [Mapserver-users] Retrieving shape extent -Email found in subject
Charles D. Van Dusen
charlie at im-design.net
Tue Mar 16 05:40:41 EST 2004
OK now Im confused
In order to retrieve the extent of a shape by its internal index, the
mode setting in the url must be set to 'indexquery'. If desired, the
mode setting can be 'indexquerymap' and a map with the selected shape
highlighted in the default yellow will be returned.
>From what I understand in the tutorials, a mode of 'map' will stream the
image directly back to the browser while a mode of 'browse' will write
the map image to disk where it can be retrieved with the [img] tag in a
template. What I have heard in this thread is that using the
'indexquery' mode will return the extent of the shape to the [shpext]
tag in the template and will write the map image to disk and its url to
[img] in the template. When I use 'indexquery' as the mode, I do not see
any images being written to the temp directory on disk.
It is as if there should be an 'indexquerybrowse' mode. Is there?
Confused...
Charlie
Charlie Van Dusen
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Steve Lime
Sent: Monday, March 15, 2004 2:49 PM
To: Charles D. Van Dusen; mapserver-users at lists.gis.umn.edu
Subject: RE: [SPAM] - Re: [Mapserver-users] Retrieving shape extent
Assuming you're using a query map you'd just use the [img] tag to get at
the image. No extra trip necessary. You can also build images based on
query results independent of the query map.
Steve
>>> "Charles D. Van Dusen" <charlie at im-design.net> 3/15/2004 1:16:03 PM
OK (understood)
So, how do I get the map while in non-map mode? Does it require an extra
round-trip to the server or is the image created?
Im working with the 'workshop' demos (specifically the dhtml banding box
demo), which I believe has its template specified as
'itasca_adds_dhtml.html'.
TIA
Charlie
Charlie Van Dusen
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Monday, March 15, 2004 1:15 PM
Subject: [SPAM] - Re: [Mapserver-users] Retrieving shape extent - Email
found in subject
When you're in a ...MAP mode you only get the map, that's the point.
However you can
still get a map with in a non-map mode, but you work through a template
instead. Won't that work for you?
Steve
>>> "Charles D. Van Dusen" <charlie at im-design.net> 3/13/2004 11:38:59
AM >>>
Greetings All,
Is it possible to retrieve the extent of a shape selected whil in
'indexquerymap' mode?
So far I have not been able to retrieve anything but the image of the
selected shape. I need to have the extent ([shpext]) as well, but I have
only been able to retrieve it in 'indexquery' mode.
Any ideas
Thanks
Charlie
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
