[SPAM] - Re: [Mapserver-users] Retrieving shape extent -Email
found in subject
Palle Due Larsen
palle at mail-online.dk
Tue Mar 16 07:01:26 EST 2004
Not need to be confused, it's quite simple really (if you know how it
works).
Any mode that ends with "map2, and the "legend" mode and the "scalebar"
mode return binary content.
All other modes process a template and return what is required for that
template. If there is a any sort of [img] placeholder in the template,
the relevant map will be produced and the image name will be returned.
If you have no [img], mapserver will not bother making a map.
Best regards
Palle Due Larsen
Carl Bro GIS&IT
-----Original Message-----
From: "Charles D. Van Dusen" <charlie at im-design.net>
To: "Steve Lime" <steve.lime at dnr.state.mn.us>,
<mapserver-users at lists.gis.umn.edu>
Date: Tue, 16 Mar 2004 05:40:41 -0500
Subject: RE: [SPAM] - Re: [Mapserver-users] Retrieving shape extent
-Email found in subject
> OK now Im confused
> In order to retrieve the extent of a shape by its internal index, the
> mode setting in the url must be set to 'indexquery'. If desired, the
> mode setting can be 'indexquerymap' and a map with the selected shape
> highlighted in the default yellow will be returned.
> From what I understand in the tutorials, a mode of 'map' will stream
> the
> image directly back to the browser while a mode of 'browse' will
> write
> the map image to disk where it can be retrieved with the [img] tag in
> a
> template. What I have heard in this thread is that using the
> 'indexquery' mode will return the extent of the shape to the [shpext]
> tag in the template and will write the map image to disk and its url
> to
> [img] in the template. When I use 'indexquery' as the mode, I do not
> see
> any images being written to the temp directory on disk.
> It is as if there should be an 'indexquerybrowse' mode. Is there?
> Confused...
> Charlie
> Charlie Van Dusen
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Steve
> Lime
> Sent: Monday, March 15, 2004 2:49 PM
> To: Charles D. Van Dusen; mapserver-users at lists.gis.umn.edu
> Assuming you're using a query map you'd just use the [img] tag to get
> at
> the image. No extra trip necessary. You can also build images based
> on
> query results independent of the query map.
> Steve
> >>> "Charles D. Van Dusen" <charlie at im-design.net> 3/15/2004 1:16:03
> PM
> OK (understood)
> So, how do I get the map while in non-map mode? Does it require an
> extra
> round-trip to the server or is the image created?
> Im working with the 'workshop' demos (specifically the dhtml banding
> box
> demo), which I believe has its template specified as
> 'itasca_adds_dhtml.html'.
> TIA
> Charlie
> Charlie Van Dusen
> From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
> Sent: Monday, March 15, 2004 1:15 PM
> Subject: [SPAM] - Re: [Mapserver-users] Retrieving shape extent -
> Email
> found in subject
> When you're in a ...MAP mode you only get the map, that's the point.
> However you can
> still get a map with in a non-map mode, but you work through a
> template
> instead. Won't that work for you?
> Steve
> >>> "Charles D. Van Dusen" <charlie at im-design.net> 3/13/2004 11:38:59
> AM >>>
> Greetings All,
> Is it possible to retrieve the extent of a shape selected whil in
> 'indexquerymap' mode?
> So far I have not been able to retrieve anything but the image of the
> selected shape. I need to have the extent ([shpext]) as well, but I
> have
> only been able to retrieve it in 'indexquery' mode.
> Any ideas
> Thanks
> Charlie
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Få en gratis emailkonto her: www.mail-online.dk
Deltag i en lille konkurrence på nettet, og
vind et gavekort på 50.000 kroner...
KLIK HER: www.nyhedsbasen.dk/konkurrence
