[Mapserver-users] virtual layers befor map file layers
Gijs Epping
gijs at gijs.com
Tue Mar 16 08:37:27 EST 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0001_01C40B64.34CB4B70
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hello,
I added some virtual layers, but before i do, i add the map file with
his own layers (some point data). The problem is that the POINT layers
are added before the RASTER layers and so you don't see them because
they are behind the rasters.
How can you reverse this or change the index of the map layers or
dynamic layers.
Thanks in advance
Gijs
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C40B64.32F33010">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0cm;
font-size:12.0pt;
span.EmailStijl17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:595.3pt 841.9pt;
margin:70.85pt 70.85pt 70.85pt 70.85pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:Standaardtabel;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DNL link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><span class=3DSpellE><font size=3D3 face=3D"Times =
New Roman"><span
style=3D'font-size:12.0pt'>Hello</span></font></span>,<o:p></o:p></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
lang=3DEN-GB
style=3D'font-size:12.0pt;mso-ansi-language:EN-GB'>I added some virtual =
layers,
but before <span class=3DSpellE>i</span> do, <span =
class=3DSpellE>i</span> add the
map file with <span class=3DGramE>his own</span> layers (some point =
data). The problem
is that the POINT layers are added before the RASTER layers and so you =
don’t
see them because they are behind the <span =
class=3DSpellE>rasters</span>. <o:p></o:p></span></font></p>
lang=3DEN-GB
style=3D'font-size:12.0pt;mso-ansi-language:EN-GB'><o:p> </o:p></spa=
n></font></p>
lang=3DEN-GB
style=3D'font-size:12.0pt;mso-ansi-language:EN-GB'>How can you reverse =
this or
change the index of the map layers or dynamic =
layers.<o:p></o:p></span></font></p>
lang=3DEN-GB
n></font></p>
lang=3DEN-GB
style=3D'font-size:12.0pt;mso-ansi-language:EN-GB'>Thanks in =
advance<o:p></o:p></span></font></p>
lang=3DEN-GB
n></font></p>
lang=3DEN-GB
style=3D'font-size:12.0pt;mso-ansi-language:EN-GB'>Gijs<o:p></o:p></span>=
</font></p>
</div>
</body>
</html>
------=_NextPart_000_0001_01C40B64.34CB4B70--
