[Mapserver-users] virtual layers befor map file layers
Eric Bridger
eric at gomoos.org
Tue Mar 16 08:56:02 EST 2004
The order of you layers in your map file IS significant. Your raster
layers must come first, then you points. If you are using mapscript the
same principal applies, raster or polygon layers should be drawn first
then your points.
On Tue, 2004-03-16 at 08:37, Gijs Epping wrote:
> Hello,
> I added some virtual layers, but before i do, i add the map file with
> his own layers (some point data). The problem is that the POINT layers
> are added before the RASTER layers and so you don't see them because
> they are behind the rasters.
> How can you reverse this or change the index of the map layers or
> dynamic layers.
> Thanks in advance
> Gijs
