[Mapserver-users] virtual layers befor map file layers
Gijs Epping
gijs at gijs.com
Tue Mar 16 09:30:08 EST 2004
Well i understand that but how can I add the dynamic layer before the
map layers it is now like this:
$gpoMap = ms_newMapObj("mapfiles/test.map");
virtual_layers($gpoMap);
One content of the virtual_layer function looks like this:
$layer1 = ms_newlayerObj($map);
$layer1->set("name", "raster1");
$layer1->set("group", "astandaard");
$layer1->setMetaData("LYRNAME","lyrraster1");
$layer1->set("type", MS_LAYER_RASTER);
$layer1->set("status", MS_ON);
$layer1->set("minscale", 30000);
$layer1->set("maxscale", 150000);
$layer1->set("tileindex",
'/var/www/html/datalocal/tileindex/raster1.shp');
$layer1->set("tileitem", location);
The result of this in an array looks like this:
Array ( [0] => nederland [1] => pointdata [2] => MapLayer [3] => raster1
[4] => raster2 [5] => raster3 [6] => raster4 )
The rasters must load before the pointdata. So what you are telling me
is that I never can change to load order of the map may it be virtual or
dynamical the load order cannot be changed.
-----Oorspronkelijk bericht-----
Van: Eric Bridger [mailto:eric at gomoos.org]
Verzonden: dinsdag 16 maart 2004 14:56
Aan: Gijs Epping
CC: Mapserver List
Onderwerp: Re: [Mapserver-users] virtual layers befor map file layers
The order of you layers in your map file IS significant. Your raster
layers must come first, then you points. If you are using mapscript the
same principal applies, raster or polygon layers should be drawn first
then your points.
On Tue, 2004-03-16 at 08:37, Gijs Epping wrote:
> Hello,
> I added some virtual layers, but before i do, i add the map file with
> his own layers (some point data). The problem is that the POINT layers
> are added before the RASTER layers and so you don't see them because
> they are behind the rasters.
> How can you reverse this or change the index of the map layers or
> dynamic layers.
> Thanks in advance
> Gijs
