[Mapserver-users] raster layers with perl mapscript
Lowell Filak
lfilak at medinaco.org
Tue Mar 16 12:41:17 EST 2004
This is probably dependant on how the script is rendering the layers.
What if you edit the script/mapfile to draw only the raster layer?
Lowell
The following message was sent by Jeff Hoffmann <jeff at propertykey.com>
on Tue, 16 Mar 2004 10:55:28 -0600.
> I'm having trouble getting a raster layer to display from within a perl
> mapscript program. I have a map file set up with several layers, only
> two of which are on by default: a raster layer (aerials) and a line
> layer (street_names), plus a scalebar. There are other layers that
> aren't on by default but may be turned on by the script. When I run the
> CGI using the map file, it gives me the two layers and the scalebar.
> The perl mapscript using the same map file and the same location only
> gives me the street_names layer, not the aerials or the scalebar. The
> script does claim to draw the aerials layer, but nothing gets output.
> What things should I be looking at to figure out why this is happening?
> Jeff Hoffmann
> PropertyKey.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
