[Mapserver-users] postgis order by
    David Blasby
    dblasby at refractions.net
    Tue Mar 16 11:39:04 PST 2004
Nick Petersen-Bergeron wrote:
> The order by seems to be ignored doing this.
1. are you ordering in the correct direction?  (i.e. the query I gave
you puts them in "1,2,3,4..." order.  If you want them in
"100,99,98,..." order, you'll need to add 'DESC' to your query.)
2. is the column your sorting on the correct datatype?  For example, if
you have integer values stored as strings, the sort will be incorrect
(i.e. "1","10","100","11",...).
If you put a "DEBUG TRUE" in your layer, and you see the "ORDER BY"
clause in your query, then the database is almost certainly doing what
you ask.
dave
More information about the MapServer-users
