[Mapserver-users] Unable to display data stored in Oracle Spatial
Fortin,Nicolas [SteFoy]
nicolas.fortin at ec.gc.ca
Wed Mar 17 11:44:37 EST 2004
Hi Jiri,
You should use a PROJECTION element in your mapfile for this layer or you should add USING SRID XXXXX at the end of your DATA request.
Example:
LAYER
NAME "3"
TYPE POLYGON
CONNECTIONTYPE oraclespatial
CONNECTION "uid/pwd at dbname"
DATA "GEOLOC FROM USR_WATERSHED.VWTRSD_LCC USING SRID 3000000"
STATUS OFF
DUMP TRUE
PROJECTION
"proj=lcc"
"ellps=GRS80"
"lat_0=63"
"lon_0=-91.8666"
"lat_1=49"
"lat_2=77"
"x_0=6200000"
"y_0=2958000"
"datum=NAD83"
"units=m"
END
CLASS
NAME "Watershed"
SYMBOL 'CIRCLE'
SIZE 2
COLOR 255 255 255
OUTLINECOLOR 0 204 0
END
END # Watershed
Nicolas
-----Message d'origine-----
De : Jiri Potocny [mailto:potocny at espace.cz]
Envoyé : Wednesday, March 17, 2004 10:54 AM
À : mapserver-users at lists.gis.umn.edu
Objet : [Mapserver-users] Unable to display data stored in Oracle Spatial
Dear MapServer experts,
could you please help me with following problem?
I'm trying to display data strored in Oracle Spatial, but I allways get a blank map. The map file is as follows:
MAP
IMAGETYPE PNG
EXTENT -551051 -1288960 -548185 -1286773
SIZE 800 600
IMAGECOLOR 255 255 255
LAYER
NAME parcels
DUMP TRUE
STATUS DEFAULT
TYPE POLYGON
CONNECTION username/password at netservisname
DATA "BOUNDARY FROM PARCELS"
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
END
If I export the data from oracle into the shapefile and use following map file, everything is O.K.
MAP
IMAGETYPE PNG
SIZE 800 600
SHAPEPATH "data"
LAYER
NAME parcely
DUMP TRUE
STATUS DEFAULT
TYPE POLYGON
DATA PARCELS
CLASS
COLOR 232 232 232
END
END
END
The only difference is in the data source, the data (attributes as well as
geometries) are the same. I'm running MapServer 4.0.1 with Oracle Spatial support (downloaded from
http://hypnos.cbs.umn.edu/projects/downloads/ms401_png_oracle.zip) and Oracle Database Server version 9.2.0.1.0 on Windows 2000 Professional SP 3.
Could anybody get throught this problem.
Much appreciated,
Jirka
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
