[Mapserver-users] Unable to display data stored in Oracle Spatial
Jiri Potocny
potocny at espace.cz
Wed Mar 17 10:53:43 EST 2004
Dear MapServer experts,
could you please help me with following problem?
I'm trying to display data strored in Oracle Spatial, but I allways get a
blank map.
The map file is as follows:
MAP
IMAGETYPE PNG
EXTENT -551051 -1288960 -548185 -1286773
SIZE 800 600
IMAGECOLOR 255 255 255
LAYER
NAME parcels
DUMP TRUE
STATUS DEFAULT
TYPE POLYGON
CONNECTIONTYPE oraclespatial
CONNECTION username/password at netservisname
DATA "BOUNDARY FROM PARCELS"
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
END
If I export the data from oracle into the shapefile and use following map
file, everything is O.K.
MAP
IMAGETYPE PNG
SIZE 800 600
SHAPEPATH "data"
LAYER
NAME parcely
DUMP TRUE
STATUS DEFAULT
TYPE POLYGON
DATA PARCELS
CLASS
COLOR 232 232 232
END
END
END
The only difference is in the data source, the data (attributes as well as
geometries) are the same. I'm running MapServer 4.0.1 with Oracle Spatial
support (downloaded from
http://hypnos.cbs.umn.edu/projects/downloads/ms401_png_oracle.zip) and
Oracle Database Server version 9.2.0.1.0 on Windows 2000 Professional SP 3.
Could anybody get throught this problem.
Much appreciated,
Jirka
