[Mapserver-users] PHP MapScript on Mac OS X?
Wheaton, William D.
wdw at rti.org
Thu Mar 18 16:57:48 EST 2004
Gary--
I was able to build mapserver (and php/mapscript) 3.7 on Macos 10.2.3 ...I
created some fairly detailed instructions that might still be of use to you
(even though mapserver is at 4.0 and Macos is at 10.3)...
The document is at http://home.nc.rr.com/wwheaton (and it's linked at the
bottom of this mapserver wiki page:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MacOS). It might answer some of
your questions about where the php_mapscript.so goes and what the httpd.conf
file show look like. Good luck.
Bill
Bill Wheaton
RTI International
P.O. 12194, 3040 Cornwallis Rd.
RTP, NC 27709
wdw at rti.org, 919-541-6158 (V), 919-541-8830 (F)
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Gary Condon
Sent: Thursday, March 18, 2004 3:56 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] PHP MapScript on Mac OS X?
Lorenzo,
Thanks for the info. I have a couple of questions ...
- Where do you store the compiled php_mapscript.so?
- Do you use PHP's dl() command to load the extension? If so, does it
return anything? Also, does the extension_loaded() function return
true?
- Could you email a copy of your httpd.conf & php.ini files (and your
php configure string if you have it)? I would be appreciative.
Gary
> Message: 43
> Date: Thu, 18 Mar 2004 15:22:08 +0100
> From: Lorenzo Moretti <lorenzo.moretti at bologna.enea.it>
> I'm using MapServer-MapScript 4.0.1 under OSX 10.2.8. It works very
> well and it's speed....
> I have build mapserver/mapscript with PHP 4.3.3. Gdal is 1.1.9. I'm
> working for a simple installer for all OS X users with last GDAL-OGR
> 1.2.0 like my Grass Gis Complete on MAC OS X (see
> http://wwwamb.bologna.enea.it/forgrass/ ). It's possible to work with
> PHP/MapScript (.phtml suffix) toghether with PHP for Apache (.php)
> with Apache under OS X.
> Now I have
> /usr/local/php (normal php 4.3.3 for Apache)
> /usr/local/php_cgi (all php 4.3.3 as CGI)
> /WebServer/CGI-PHPMapServer (inside there is only a php link to
> /usr/local/php_cgi/bin/php)
> /WebServer/CGI-Executables (inside there is mapserv)
> /sw (all libraries for mapserver and php from
FINK)
> The goal is to build MapServer Complete without Fink and with the last
> libraries with double clic installer.
> Bye
> _______________________________________________________________________
> _
> || Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
> ||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
> || | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/
> (res.)
> ~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
> Download GRASS for MAC OS X:
> _
> _
> --============_-1132502765==_ma============
> Content-Type: text/plain; charset="us-ascii" ; format="flowed"
>> Gary,
>> These instructions provide some hints on support library builds and
>> compiling mapserver, though they are a little out of date:
>> With a recent version of OS X like 10.3 and recent versions of
>> mapserver (from cvs) the build should proceed without problems after
>> running configure.
>> I encourage you to add any updated solutions you find to the wiki
>> page above, so that others can benefit from your experiences.
>> zak
>> Zak James
>> Applications and Software Development
>> DM Solutions Group Inc.
>> http://www.dmsolutions.ca
>> On Mar 16, 2004, at 12:49 PM, Gary Condon wrote:
>>> All,
>>> I am trying to get PHP MapScript up and running on Mac OS X 10.3
>>> but, so far, without success.
>>> I have tried using the precompiled version provided by Server
>>> Logistics but I can't dl() the module under PHP 4.3.4 or 5.0b4.
>>> Has anybody out there gotten this to work? If so, how?
>>> Thanks is advance,
>>> Gary
>>> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
