[Mapserver-users] PHP MapScript on Mac OS X?
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Fri Mar 19 05:32:11 EST 2004
--============_-1132430164==_ma============
Content-Type: text/plain; charset="us-ascii" ; format="flowed"
Gary
>- Where do you store the compiled php_mapscript.so?
Now I have
/usr/local/php (normal php 4.3.3 for Apache)
/usr/local/php_cgi (all php 4.3.3 as CGI)
/usr/local/php_cgi/lib/php/extensions/no-debug-non-zts-20020429/php_mapscript.so
/WebServer/CGI-PHPMapServer (inside there is only a php link to
/usr/local/php_cgi/bin/php)
/WebServer/CGI-Executables (inside there is mapserv)
/sw (all libraries for mapserver and php from FINK)
>- Do you use PHP's dl() command to load the extension? If so, does
>it return anything? Also, does the extension_loaded() function
>return true?
Yes. In namefile.phtml
/* Load required modules */
if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
$dlext = "dll";
else
$dlext = "so";
if (!extension_loaded("MapScript"))
dl("php_mapscript.$dlext");
if (!extension_loaded("dbase"))
dl("php_dbase.$dlext");
>- Could you email a copy of your httpd.conf & php.ini files (and
>your php configure string if you have it)? I would be appreciative.
I have not create php.ini but it's possible.
My httpd.conf for 2 php (Apache DSO and cgi)
normal PHP for apache
LoadModule perl_module libexec/httpd/libperl.so
LoadModule php4_module /usr/local/php/libphp4.so
LoadModule dav_module libexec/httpd/libdav.so
AddModule mod_php4.c
AddModule mod_dav.c
for index
# DirectoryIndex: Name of the file or files to use as a pre-written HTML
# directory index. Separate multiple entries with spaces.
<IfModule mod_dir.c>
DirectoryIndex index.html index.htm default.html default.htm
index.php default.php index.phtml
</IfModule>
inside section <IfModule mod_alias.c>
# PHP Map Server ---
ScriptAlias /cgi-map/ "/WebServer/CGI-PHPMapServer/"
<Directory "/WebServer/CGI-PHPMapServer">
Options ExecCGI FollowSymLinks
</Directory>
after Action
# Action lets you define media types that will execute a script whenever
# a matching file is called. This eliminates the need for repeated URL
# pathnames for oft-used CGI file processors.
# Format: Action media/type /cgi-script/location
# Format: Action handler-name /cgi-script/location
Action phtml-script /cgi-map/php
AddHandler phtml-script .phtml
All .php files work with normal PHP and all .phtml files work with CGI PHP.
They work very very well with last MapServer 4.0.1 in an old G3 beige....
Bye
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (res.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
Download GRASS for MAC OS X:
http://wwwamb.bologna.enea.it/forgrass/
Content-Type: text/html; charset="us-ascii"
<!doctype html public "-//W3C//DTD W3 HTML//EN">
<html><head><style type="text/css"><!--
blockquote, dl, ul, ol, li { padding-top: 0 ; padding-bottom: 0 }
--></style><title>Re: [Mapserver-users] PHP MapScript on Mac OS
X?</title></head><body>
<div>Gary</div>
<div><br></div>
<blockquote type="cite" cite>- Where do you store the compiled
php_mapscript.so?</blockquote>
<div><br></div>
<div><br></div>
<div>Now I have</div>
<blockquote><font face="Courier">/usr/local/php<x-tab>
</x-tab><x-tab>
</x-tab><x-tab>
</x-tab>(normal php 4.3.3 for Apache)</font></blockquote>
<blockquote><font
face="Courier">/usr/local/php_cgi<x-tab>
</x-tab><x-tab> </x-tab>(all
php 4.3.3 as CGI)</font></blockquote>
<blockquote><font face="Courier"><br></font></blockquote>
<blockquote><font
face="Courier"
>/usr/local/php_cgi/lib/php/extensions/no-debug-non-zts-20020429/php_<span
></span>mapscript.so</font></blockquote>
<blockquote><font
face="Courier">/WebServer/CGI-PHPMapServer<x-tab>
</x-tab>(inside there is only a php link to
/usr/local/php_cgi/bin/php)</font></blockquote>
<blockquote><font
face="Courier">/WebServer/CGI-Executables<x-tab
mapserv)</font></blockquote>
<blockquote><font face="Courier">/sw<x-tab>
</x-tab><x-tab>
</x-tab><x-tab>
libraries for mapserver and php from FINK)</font></blockquote>
<blockquote><br></blockquote>
<div><br></div>
<blockquote type="cite" cite>- Do you use PHP's dl() command to load
the extension? If so, does it return anything? Also, does
the extension_loaded() function return true?</blockquote>
<div><br></div>
<div>Yes. In namefile.phtml</div>
<div><br></div>
<blockquote><font face="Courier New">/*
*/</font></blockquote>
Load required
modules <span
></span
> <span
></span
> <span
></span>
<blockquote><font face="Courier New">if (PHP_OS == "WINNT"
|| PHP_OS == "WIN32")</font></blockquote>
<blockquote><font face="Courier New">{</font></blockquote>
<blockquote><font face="Courier New"> $dlext =
"dll";</font></blockquote>
<blockquote><font face="Courier New">}</font></blockquote>
<blockquote><font face="Courier New">else</font></blockquote>
"so";</font></blockquote>
<blockquote><font face="Courier New"><br></font></blockquote>
(!extension_loaded("MapScript"))</font></blockquote>
dl("php_mapscript.$dlext");</font></blockquote>
(!extension_loaded("dbase"))</font></blockquote>
dl("php_dbase.$dlext");</font></blockquote>
<div><br></div>
<div><br></div>
<blockquote type="cite" cite>- Could you email a copy of your
httpd.conf & php.ini files (and your php configure string if you
have it)? I would be appreciative.<br>
</blockquote>
<div><br></div>
<div>I have not create php.ini but it's possible.</div>
<div><br></div>
<div>My httpd.conf for 2 php (Apache DSO and cgi)</div>
<div><br></div>
<blockquote>normal PHP for apache</blockquote>
<div><br></div>
<blockquote>
<blockquote><font face="Courier New">...</font></blockquote>
<blockquote><font face="Courier New">LoadModule
perl_module
libexec/httpd/libperl.so</font></blockquote>
php4_module
/usr/local/php/libphp4.so</font></blockquote>
dav_module
libexec/httpd/libdav.so</font></blockquote>
<blockquote><font face="Courier New">AddModule
mod_php4.c</font></blockquote>
mod_dav.c</font></blockquote>
<blockquote><font face="Courier New">....</font></blockquote>
</blockquote>
<blockquote>for index
<blockquote><font face="Courier New">#<br>
HTML<br>
# directory index. Separate multiple entries with spaces.<br>
#<br>
<IfModule mod_dir.c><br>
default.htm index.php default.php index.phtml</font></blockquote>
<blockquote><font
face="Courier New"></IfModule></font></blockquote>
</blockquote>
<blockquote>inside section <IfModule mod_alias.c>
<blockquote><font face="Courier New"># PHP Map Server
---</font></blockquote>
</blockquote>
<blockquote><font face="Courier New"> ScriptAlias
/cgi-map/ "/WebServer/CGI-PHPMapServer/"</font>
<blockquote><font face="Courier New"><Directory
"/WebServer/CGI-PHPMapServer"></font></blockquote>
</blockquote>
<blockquote><font
face="Courier New"><x-tab>
</x-tab>Options ExecCGI FollowSymLinks</font>
<blockquote><font
face="Courier New"></Directory></font></blockquote>
</blockquote>
<blockquote>after Action
whenever<br>
URL<br>
# pathnames for oft-used CGI file processors.<br>
# Format: Action media/type /cgi-script/location</font></blockquote>
<blockquote><font face="Courier New"># Format: Action handler-name
/cgi-script/location<br>
#<br>
<br>
Action phtml-script /cgi-map/php</font></blockquote>
<blockquote><font face="Courier New">AddHandler phtml-script
</blockquote>
<div>All .php files work with normal PHP and all .phtml files work
with CGI PHP.</div>
<div><br></div>
<div>They work very very well with last MapServer 4.0.1 in an old G3
beige....</div>
<div><br></div>
<div>Bye</div>
<div><br></div>
<x-sigsep><pre>--
</pre></x-sigsep>
<div><font face="Courier New"
color="#000000"
>____________________________________________________________________<span
></span>____</font></div>
color="#000000">|| Lorenzo
Moretti e-mail:
lorenzo.moretti at bologna.enea.it </font></div
<div><font face="Courier New" color="#000000">||/|/| ENEA
prot/idr Web:
http://wwwamb.bologna.enea.it/ </font></div>
<div><font face="Courier New" color="#000000">|| |
ftp://ftpamb.bologna.enea.it/ (res.)</font></div>
<div><font face="Courier New" color="#000000">~~~~~~ 40128
+39-0516098131</font></div>
color="#000000"><x-tab>
</x-tab><x-tab>
</x-tab><x-tab>
</x-tab>Download GRASS for MAC OS
X: </font></div>
</x-tab>
http://wwwamb.bologna.enea.it/forgrass/</font></div>
color="#000000"
</body>
</html>
--============_-1132430164==_ma============--
