[Mapserver-users] PHP MapScript on Mac OS X?
Gary Condon
gcondon at ll.mit.edu
Thu Mar 18 15:55:51 EST 2004
Lorenzo,
Thanks for the info. I have a couple of questions ...
- Where do you store the compiled php_mapscript.so?
- Do you use PHP's dl() command to load the extension? If so, does it
return anything? Also, does the extension_loaded() function return
true?
- Could you email a copy of your httpd.conf & php.ini files (and your
php configure string if you have it)? I would be appreciative.
Gary
> Message: 43
> Date: Thu, 18 Mar 2004 15:22:08 +0100
> To: mapserver-users at lists.gis.umn.edu
> From: Lorenzo Moretti <lorenzo.moretti at bologna.enea.it>
> Subject: Re: [Mapserver-users] PHP MapScript on Mac OS X?
> I'm using MapServer-MapScript 4.0.1 under OSX 10.2.8. It works very
> well and it's speed....
> I have build mapserver/mapscript with PHP 4.3.3. Gdal is 1.1.9. I'm
> working for a simple installer for all OS X users with last GDAL-OGR
> 1.2.0 like my Grass Gis Complete on MAC OS X (see
> http://wwwamb.bologna.enea.it/forgrass/ ).
> It's possible to work with PHP/MapScript (.phtml suffix) toghether
> with PHP for Apache (.php) with Apache under OS X.
> Now I have
> /usr/local/php (normal php 4.3.3 for Apache)
> /usr/local/php_cgi (all php 4.3.3 as CGI)
> /WebServer/CGI-PHPMapServer (inside there is only a php link to
> /usr/local/php_cgi/bin/php)
> /WebServer/CGI-Executables (inside there is mapserv)
> /sw (all libraries for mapserver and php from FINK)
> The goal is to build MapServer Complete without Fink and with the
> last libraries with double clic installer.
> Bye
> _______________________________________________________________________
> _
> || Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
> ||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
> || | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/
> (res.)
> ~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
> Download GRASS for MAC OS X:
> _
> --============_-1132502765==_ma============
> Content-Type: text/plain; charset="us-ascii" ; format="flowed"
>> Gary,
>> These instructions provide some hints on support library builds and
>> compiling mapserver, though they are a little out of date:
>> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MacOS
>> With a recent version of OS X like 10.3 and recent versions of
>> mapserver (from cvs) the build should proceed without problems after
>> running configure.
>> I encourage you to add any updated solutions you find to the wiki
>> page above, so that others can benefit from your experiences.
>> zak
>> Zak James
>> Applications and Software Development
>> DM Solutions Group Inc.
>> http://www.dmsolutions.ca
>> On Mar 16, 2004, at 12:49 PM, Gary Condon wrote:
>>> All,
>>> I am trying to get PHP MapScript up and running on Mac OS X 10.3
>>> but, so far, without success.
>>> I have tried using the precompiled version provided by Server
>>> Logistics but I can't dl() the module under PHP 4.3.4 or 5.0b4.
>>> Has anybody out there gotten this to work? If so, how?
>>> Thanks is advance,
>>> Gary
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
