AW: [Mapserver-users] Anti-Aliasing of lines
"Weßling, Achim"
Achim.Wessling at gt-net.de
Fri Mar 19 05:29:53 EST 2004
Hallo,
first I found an error in your docu. You added a symbol-example which looks
as follows:
SYMBOL
NAME "cartoline"
TYPE cartoline
LINECAP butt
LINEJOIN miter
LINEJOINMAXSIZE 1
STYLE 10 5
END
Here the 'END' is missing in the STYLE-syntax.
Second, has someone a simple example how to use the STYLE-Object in the
map-File?
Mit freundlichem Gruß
Achim Weßling
INFOKOM Gütersloh AöR
Fachbereich Technische Anwendungen
Herzebrocker Str. 140
33334 Gütersloh
Tel.: 05241/85-2926
http://www.infokom-gt.de
-----Ursprüngliche Nachricht-----
Von: Tomas Krecmer [mailto:tokr at tmapy.cz]
Gesendet am: Freitag, 19. März 2004 08:29
An: Alexander Pucher
Cc: Steve Lime; mapserver-users at lists.gis.umn.edu
Betreff: Re: [Mapserver-users] Anti-Aliasing of lines
There is support in MapServer 4.x right now. Use a cartoline symbol. See
the attached documentation.
Tomas
Alexander Pucher wrote:
> Hi all,
> Steve, please excuse if this isn't the right place for this
> discussion. I checked the GD documentation
> (http://www.boutell.com/gd/manual2.0.22.html) and found this:
> What's new in version 2.0.12?
> Support for fast drawing of antialiased lines and polygons, by Bright
> Fulton and Frank Faubert. To learn more about this feature, read about
> the gdImageSetAntiAliased
> <http://www.boutell.com/gd/manual2.0.22.html#gdImageSetAntiAliased>
> function, which is used to set the foreground color for antialiasing,
> as well as the gdAntiAliased
> <http://www.boutell.com/gd/manual2.0.22.html#gdAntiAliased> constant,
> which is passed to line- and polygon-drawing functions in place of a
> color.
> gdAntiAliasing(CONSTANT)
> Used in place of a color when invoking a line-drawing function such as
> gdImageLine <http://www.boutell.com/gd/manual2.0.22.html#gdImageLine>
> or gdImageRectangle
> <http://www.boutell.com/gd/manual2.0.22.html#gdImageRectangle>. When
> gdAntiAliased is used as the color, the foreground color set with
> <http://www.boutell.com/gd/manual2.0.22.html#gdImageSetAntiAliased> is
> used, with antialiasing mechanisms to minimize any "jagged"
> appearance. For more information, see gdImageSetAntiAliased
> <http://www.boutell.com/gd/manual2.0.22.html#gdImageSetAntiAliased>.
> So, it seems that GD is able to draw anti-aliased lines. Is there a
> way to let mapserver use these functionality?
> Thanks for any input.
> alex.
> Steve Lime wrote:
>> Yup, we can do what GD does at this point.
>> Steve
>>>>> Alexander Pucher <pucher at atlas.gis.univie.ac.at> 3/17/2004 8:12:14
>> AM >>>
>> Hi,
>> what is the recent status of anti-aliasing of lines in MapServer. The
>> limitation is GD, is this correct?
>> regards,
>> alex.
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Tomas Krecmer, tomas.krecmer at tmapy.cz
T-MAPY spol. s r.o., Nezvalova 850, 500 03 Hradec Kralove,
Czech Republic, phone: + 420 49 5513335 , fax + 420 49 5513371
