[Mapserver-users] cgi: QueryByPoint no results
K Resellmo
mapserver at resellmo.com
Mon Mar 22 00:37:25 EST 2004
Hello all,
I'm trying to get mapqueries to work with Mapserver 4.0.1, but QueryByPoint
always returns "no results." I have tried zooming in to make sure I really
click the right point / polygon, but that has not helped. Changing the
TOLERANCE setting did not help either.
I am using shapefiles from http://nationalatlas.gov/, and I have tried to
use both point and polygon layers without being able to get any query results.
Help would be greatly appreciated. Below is my mapfile and template file.
Thanks in advance!
Kris
MAP
IMAGETYPE GIF
EXTENT -97.5 41.619778 -82.122902 49.38562
SIZE 400 300
SHAPEPATH "d:/vagabond/mapdata"
WEB
TEMPLATE '/mapserver/web/map-query.html'
IMAGEPATH '/mapserver/web/images/'
IMAGEURL '/mapserver/images/'
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME States
DATA statesp020
STATUS DEFAULT
TYPE POLYGON
CLASS
STYLE
COLOR 255 204 102
END
END
END # States polygon layer ends here
LAYER # States line layer begins here
NAME States
DATA statesp020
STATUS DEFAULT
TYPE LINE
CLASS
STYLE
COLOR 32 32 32
END
END
END # States line layer ends here
LAYER # urban areas layer begins here
NAME urbanAreas
DATA urbanap020
STATUS default
TYPE POLYGON
CLASS
STYLE
COLOR 255 0 0
END
END
END # end of urban areas layer
END # end of map file/object
HTML template file:
<html>
<head></head>
<body>
<form name="mapserv" method="GET" action="/cgi-bin/mapserv.exe"
ID="Form1">
<input type="hidden" name="map"
value="/mapserver/web/map-query.map" ID="Hidden1">
<input type="hidden" name="imgext" value="[mapext]" ID="Hidden2">
<input type="hidden" name="imgxy" value="199.5 149.5" ID="Hidden3">
<input type="hidden" name="zoom" value="1" ID="Hidden4">
<select name="mode">
<option value="browse" [browse_select]>Browse </option>
<option value="query" [query_select]>Query Single Layer</option>
<option value="nquery" [nquery_select]>Query Multiple
Layers</option>
</select>
<input type="image" name="img" src="[img]" width="400"
height="300" ID="Image1">
</form>
</body>
</html>
