[Mapserver-users] Problem with MapServer 4.0.1 and Apache 2.0.48
Diego Magni
diego at geomatica.como.polimi.it
Mon Mar 22 11:24:57 EST 2004
Hi List,
I've installed MapServer 4.0.1 (Windows Binary, ms401_gif_pg.zip) with
Apache 2.0.48, but I've some problems with Legend, Scalebar and Reference
Map Objects and with TrueType fonts. When I run a MapServer application, the
map is correctly displayed into the template file, but legend, reference map
and scalebar images aren't created. Furthermore, the service runs only if I
use bitmap fonts, while if I use TrueType, there's the following error
message: "msGetLabelSize(): TrueType Font error. Could not find/open font".
Since the map is created and displayed, some template references like [id],
[host], [port], [scale] or [cellsize] work correctly and legend.exe,
scalebar.exe, etc. work properly with MS-Dos, I think that my problems can
be from an Apache misconfiguration.
Can anyone help me?
Thank you in advance,
best regards,
Diego
