[Mapserver-users] Problem with MapServer 4.0.1 and Apache 2.0.48
Zamil Murji
Zamil.Murji at divestco.com
Mon Mar 22 11:41:52 EST 2004
I had some problems a while back with Mapserver 4.0 and Apache 2.0.X. I downgraded my Apache to 1.X (sorry I don't know what the current stable release is) and everything magically started working. Maybe you should try that.
Thanks
Zamil
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Diego Magni
Sent: Monday, March 22, 2004 9:25 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Problem with MapServer 4.0.1 and Apache
2.0.48
Hi List,
I've installed MapServer 4.0.1 (Windows Binary, ms401_gif_pg.zip) with
Apache 2.0.48, but I've some problems with Legend, Scalebar and Reference
Map Objects and with TrueType fonts. When I run a MapServer application, the
map is correctly displayed into the template file, but legend, reference map
and scalebar images aren't created. Furthermore, the service runs only if I
use bitmap fonts, while if I use TrueType, there's the following error
message: "msGetLabelSize(): TrueType Font error. Could not find/open font".
Since the map is created and displayed, some template references like [id],
[host], [port], [scale] or [cellsize] work correctly and legend.exe,
scalebar.exe, etc. work properly with MS-Dos, I think that my problems can
be from an Apache misconfiguration.
Can anyone help me?
Thank you in advance,
best regards,
Diego
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
