[Mapserver-users] Problem with MapServer 4.0.1 and Apache 2.0.48
Diego Magni
diego at geomatica.como.polimi.it
Tue Mar 23 03:50:37 EST 2004
Hi Zamil and List,
thank you very much for your help; I already tried these tests:
- MapServer 4.0.1 on Apache 1.3.29 (Windows NT OS): problems with
Legend,Scalebar,ReferenceMap, TrueType;
- MapServer 3.6.7 on Apache 1.3.29 (Windows NT OS): OK;
- MapServer 3.6.7 on Apache 2.0.48 (Windows NT OS): OK.
Now, I'm interesting to use MapServer 4.0.1 on Apache with Windows 2000 OS.
Best regards,
Diego
----- Original Message -----
To: "Diego Magni" <diego at geomatica.como.polimi.it>;
<mapserver-users at lists.gis.umn.edu>
Sent: Monday, March 22, 2004 5:41 PM
Subject: RE: [Mapserver-users] Problem with MapServer 4.0.1 and Apache
2.0.48
> Hi,
> I had some problems a while back with Mapserver 4.0 and Apache 2.0.X. I
downgraded my Apache to 1.X (sorry I don't know what the current stable
release is) and everything magically started working. Maybe you should try
that.
> Thanks
> Zamil
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Diego Magni
> Sent: Monday, March 22, 2004 9:25 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Problem with MapServer 4.0.1 and Apache
> 2.0.48
> Hi List,
> I've installed MapServer 4.0.1 (Windows Binary, ms401_gif_pg.zip) with
> Apache 2.0.48, but I've some problems with Legend, Scalebar and Reference
> Map Objects and with TrueType fonts. When I run a MapServer application,
the
> map is correctly displayed into the template file, but legend, reference
map
> and scalebar images aren't created. Furthermore, the service runs only if
I
> use bitmap fonts, while if I use TrueType, there's the following error
> message: "msGetLabelSize(): TrueType Font error. Could not find/open
font".
> Since the map is created and displayed, some template references like
[id],
> [host], [port], [scale] or [cellsize] work correctly and legend.exe,
> scalebar.exe, etc. work properly with MS-Dos, I think that my problems can
> be from an Apache misconfiguration.
> Can anyone help me?
> Thank you in advance,
> best regards,
> Diego
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
