[Mapserver-users] Problem with MapServer 4.0.1 and Apache
2.0.48
bartvde at xs4all.nl
Tue Mar 23 05:30:34 EST 2004
Hi Diego,
you could have a look at MS4W, this works properly out of the box.
http://www.maptools.org/ms4w
Latest version is:
http://www.maptools.org/dl/ms4w/mapserver_ms4w-4.1-20040303.zip
Best regards,
Bart
> Hi Zamil and List,
> thank you very much for your help; I already tried these tests:
> - MapServer 4.0.1 on Apache 1.3.29 (Windows NT OS): problems with
> Legend,Scalebar,ReferenceMap, TrueType;
> - MapServer 3.6.7 on Apache 1.3.29 (Windows NT OS): OK;
> - MapServer 3.6.7 on Apache 2.0.48 (Windows NT OS): OK.
> Now, I'm interesting to use MapServer 4.0.1 on Apache with Windows 2000
> OS.
> Best regards,
> Diego
> ----- Original Message -----
> From: "Zamil Murji" <Zamil.Murji at divestco.com>
> To: "Diego Magni" <diego at geomatica.como.polimi.it>;
> <mapserver-users at lists.gis.umn.edu>
> Sent: Monday, March 22, 2004 5:41 PM
> Subject: RE: [Mapserver-users] Problem with MapServer 4.0.1 and Apache
> 2.0.48
>> Hi,
>> I had some problems a while back with Mapserver 4.0 and Apache 2.0.X. I
> downgraded my Apache to 1.X (sorry I don't know what the current stable
> release is) and everything magically started working. Maybe you should try
> that.
>> Thanks
>> Zamil
>> -----Original Message-----
>> From: mapserver-users-admin at lists.gis.umn.edu
>> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Diego Magni
>> Sent: Monday, March 22, 2004 9:25 AM
>> To: mapserver-users at lists.gis.umn.edu
>> Subject: [Mapserver-users] Problem with MapServer 4.0.1 and Apache
>> 2.0.48
>> Hi List,
>> I've installed MapServer 4.0.1 (Windows Binary, ms401_gif_pg.zip) with
>> Apache 2.0.48, but I've some problems with Legend, Scalebar and
>> Reference
>> Map Objects and with TrueType fonts. When I run a MapServer application,
> the
>> map is correctly displayed into the template file, but legend, reference
> map
>> and scalebar images aren't created. Furthermore, the service runs only
>> if
> I
>> use bitmap fonts, while if I use TrueType, there's the following error
>> message: "msGetLabelSize(): TrueType Font error. Could not find/open
> font".
>> Since the map is created and displayed, some template references like
> [id],
>> [host], [port], [scale] or [cellsize] work correctly and legend.exe,
>> scalebar.exe, etc. work properly with MS-Dos, I think that my problems
>> can
>> be from an Apache misconfiguration.
>> Can anyone help me?
>> Thank you in advance,
>> best regards,
>> Diego
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
