[Mapserver-users] Problem with MapServer 4.0.1 and Apache 2.0.48
Diego Magni
diego at geomatica.como.polimi.it
Wed Mar 24 04:38:56 EST 2004
Hi Bart,
thank you for your help: everything works correctly now (MapServer 4.1 +
Apache 2.0.46); I've solved my problems simply using absolute path for
IMAGEPATH, while in previous MapServer releases relative path is also
admitted.
Thanks,
Best regards,
Diego
----- Original Message -----
To: "Diego Magni" <diego at geomatica.como.polimi.it>
Cc: "Zamil Murji" <zamil.murji at divestco.com>;
<mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, March 23, 2004 11:30 AM
Subject: Re: [Mapserver-users] Problem with MapServer 4.0.1 and Apache
2.0.48
> Hi Diego,
> you could have a look at MS4W, this works properly out of the box.
> http://www.maptools.org/ms4w
> Latest version is:
> http://www.maptools.org/dl/ms4w/mapserver_ms4w-4.1-20040303.zip
> Best regards,
> Bart
> > Hi Zamil and List,
> > thank you very much for your help; I already tried these tests:
> > - MapServer 4.0.1 on Apache 1.3.29 (Windows NT OS): problems with
> > Legend,Scalebar,ReferenceMap, TrueType;
> > - MapServer 3.6.7 on Apache 1.3.29 (Windows NT OS): OK;
> > - MapServer 3.6.7 on Apache 2.0.48 (Windows NT OS): OK.
> > Now, I'm interesting to use MapServer 4.0.1 on Apache with Windows 2000
> > OS.
> > Best regards,
> > Diego
> > From: "Zamil Murji" <Zamil.Murji at divestco.com>
> > To: "Diego Magni" <diego at geomatica.como.polimi.it>;
> > Sent: Monday, March 22, 2004 5:41 PM
> > Subject: RE: [Mapserver-users] Problem with MapServer 4.0.1 and Apache
> > 2.0.48
> >> Hi,
> >> I had some problems a while back with Mapserver 4.0 and Apache 2.0.X. I
> > downgraded my Apache to 1.X (sorry I don't know what the current stable
> > release is) and everything magically started working. Maybe you should
try
> > that.
> >> Thanks
> >> Zamil
> >> -----Original Message-----
> >> From: mapserver-users-admin at lists.gis.umn.edu
> >> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Diego
Magni
> >> Sent: Monday, March 22, 2004 9:25 AM
> >> To: mapserver-users at lists.gis.umn.edu
> >> Subject: [Mapserver-users] Problem with MapServer 4.0.1 and Apache
> >> 2.0.48
> >> Hi List,
> >> I've installed MapServer 4.0.1 (Windows Binary, ms401_gif_pg.zip) with
> >> Apache 2.0.48, but I've some problems with Legend, Scalebar and
> >> Reference
> >> Map Objects and with TrueType fonts. When I run a MapServer
application,
> > the
> >> map is correctly displayed into the template file, but legend,
reference
> > map
> >> and scalebar images aren't created. Furthermore, the service runs only
> >> if
> > I
> >> use bitmap fonts, while if I use TrueType, there's the following error
> >> message: "msGetLabelSize(): TrueType Font error. Could not find/open
> > font".
> >> Since the map is created and displayed, some template references like
> > [id],
> >> [host], [port], [scale] or [cellsize] work correctly and legend.exe,
> >> scalebar.exe, etc. work properly with MS-Dos, I think that my problems
> >> can
> >> be from an Apache misconfiguration.
> >> Can anyone help me?
> >> Thank you in advance,
> >> best regards,
> >> Diego
> >> _______________________________________________
> >> Mapserver-users mailing list
> >> Mapserver-users at lists.gis.umn.edu
> >> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
