[Mapserver-users] WFS Anyone?
Keith Campbell
scoota at supanet.com
Mon Mar 22 18:13:42 EST 2004
Frank,
The files you speak of appear to be in /export/home/local/util/proj/nad
Assuming that this location is not being picked up, I set PROJ_LIB to
point to this directory. However, that didn't resolve the problem.
Possibly this is due to the fact i don't have admin rights, and although
the variable was reported to have changed, when I logged out and back in
again, the variable was not set. I think I will need to get the server
administrator to set this variable and try again?
Keith
Frank Warmerdam wrote:
> Keith Campbell wrote:
>> Hi Frank,
>> Thanks for your reply.
>> I've discovered what the problem was - MapServer had not been
>> compiled --with-wfs as I thought it had - D'oh! Anyway, it's been
>> recompiled appropriately and the GetCapabilities request does work.
>> However, the GetFeature request returns this error:-
>> msProcessProjection(): Projection library error. no system list,
>> errno: 2
>> So far the MapServer error messages I've come across have been
>> self-explanatory, but I'm not sure about that one. Presumably it's
>> come from PROJ4, but I don't know what system list it's referring to.
>> Any ideas? And how do I put this right?
> Keith,
> The error text you see actually indicates that the attempt to turn a
> system
> provided error number (2) into a message failed because strerrno() was
> not
> configured for use on the system. That errno value likely is ENOENT
> meaning
> basically, file not found. That is the projections library looked for
> a file,
> likely the "epsg" file but could not find it.
> This error reporting sucks, and I am at fault unfortunately.
> Anways, ensure you have the proj.4 support files fully installed (they
> usually
> would end up in /usr/local/share/proj) and then if they still aren't
> found set
> the PROJ_LIB environment variable to point to the directory where they
> are
> found. You likely need at least the "epsg" file. Possibly also the
> nad83/27
> datum shifting files if you are working with data requiring datuming
> shifting on
> the fly.
> Best regards,
